Author Topic: Strange question  (Read 5393 times)
Offline allankelly1
Strange question
« on: September 17, 2021, 07:47:39 PM »
Just wondered out of curiosity how much oil in litres per min a CB400F oil pump displaces on tick over
Any oil pump experts out there?
Best wishes Al
Re: Strange question
« Reply #1 on: September 17, 2021, 11:35:45 PM »
I have  no idea but as long as the oil light goes out reasonably quickly I think it's enough to do the job.
Offline Athame57
    • SeaWitch Artist
« Reply #2 on: September 18, 2021, 12:53:11 PM »
Assuming the oil pump completes it's cycle 1200 times a minute, perhaps you could find out the capacity of said pump and multiply? Otherwise you could ask those boffins at NASA?  ;D
« Last Edit: September 18, 2021, 12:54:46 PM by Athame57 »
1978 CB400F2 named Elen.
Online Bryanj
« Reply #3 on: September 18, 2021, 01:57:50 PM »
It pumps more than enough but not too much is the only answer i can give
Offline allankelly1
« Reply #4 on: September 18, 2021, 07:12:39 PM »
Hi thanks for all the answers
Best wishes Al
Offline Seabeowner
« Reply #5 on: September 19, 2021, 08:14:03 AM »
Best wishes Al
Depends on how worn your bearings are.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
Offline TrickyMicky
« Reply #6 on: September 19, 2021, 08:46:53 AM »
To my simplistic way of thinking, worn bearings should not alter the output of the pump. If the pump is in good order it will still pass the same amount of liquid at a given speed. Don't forget that you cannot compress a liquid, only a gas. If the pressure gets too high then there should be a by-pass valve somewhere, otherwise something will definitely break. Look what happens to the conrods and crankshafts in diesel engines when they suck in some water.
« Reply #7 on: September 19, 2021, 12:39:27 PM »
Dead right. Wear in the pump itself will affect the output. Wear in the engine bearings affects the oil pressure.
« Reply #8 on: September 19, 2021, 12:44:51 PM »
Isn’t there a pressure relief valve in the oil filter bolt?
Online Bryanj
« Reply #9 on: September 19, 2021, 12:52:20 PM »
Thats only for if the filter blocks so oil bypasses the filter and lubes the engine albeit with contaminated oil Steve, there is an over pressure relief built into the pump itself and operates at about 65psi if memory serves
« Reply #10 on: September 19, 2021, 01:29:26 PM »
The one in the pump (virtually all engines have this) is to protect the oil pump drive while the oil is thicker when cold. Essentially it will hydraulic lock (dynamic and relevant to the system resistance that is normal oil flow) if revved under those conditions and risk shearing the drive arrangement.
Offline allankelly1
Strange question
« Reply #11 on: September 19, 2021, 07:02:46 PM »
Thanks for all the answers everybody
The original reason was that I have just finished off my oil cooler installation
But  on initial checks during cranking on the starter (before firing the engine as wanted to ensure the system was flowing oil) there seemed to be less flow thru the cooler than I was expecting?
But then I remembered the there is a bypass port in the take off plate
So most flow goes direct to the engine via this port  with a percentage flowing via the cooler hence my initial worry about lack of flow of oil
Again many thanks for all the answers Al
« Last Edit: September 19, 2021, 07:05:39 PM by allankelly1 »
Offline 400 Cafe Racer
« Reply #12 on: September 19, 2021, 07:45:15 PM »
Hi Bryan, ;)
I can confirm this 65psi as I recently fitted an oil pressure gauge which tops out at 65psi when the engine is started cold. A good indication the oil pressure relief valve is functioning correctly.
Retired Automotive Engineer   MIMI, MITRE, DMS, MCMI.
Latest     - 1989 CBR600F1 (FK) PC23
              - 1979 CB400/4  Cafe Racer - Parakeet Yellow
              - 1939 Velocette GTP 250 twin port Two stroke
1988-91 - Lamborghini Countach QV replica design and
                 build - 3000hr spare time project -Now Sold
In 1956 at 12yrs old and dirt tracking
              - 1937 Rudge 500 4 valve
              - 1940s Royal Enfield 225sv
              -  Ex WD Norton 500sv
Online Bryanj
« Reply #13 on: September 19, 2021, 09:31:06 PM »
Unless you arr racingan oil cooler is overkill if not fitted with a thermostatic bypass
Offline allankelly1
« Reply #14 on: September 19, 2021, 09:33:21 PM »
No just prepping as planning to fit a 460cc lump in the future and an oil cooler was highly recommended as part of the changes when going up to 460cc
