Author Topic: Headlight problem.  (Read 5094 times)
Offline Bradders
Re: Headlight problem.
« Reply #15 on: September 22, 2021, 08:56:25 AM »
Sounds like a good idea Tricky Micky. It does look like it could do with a good clean up all round fuse box area.
Offline TrickyMicky
« Reply #16 on: September 22, 2021, 10:43:16 AM »
On a more light hearted note, and possibly a word to the wise, when I was performing this task, because it was so fiddly I took some time over it.  Everything was re-connected, fully insulated, put back into its respective position, complete set of new fuses installed. Time for the big switch on! Absolutely Nuffink!! Dead as a Dodo. I was very late for my dinner, so I thought "Bugger it", I'll start again in the morning, put all the tools away, picked up all the little plastic containers in which I put all the fixtures, fittings etc., And there, in the last container was a lonely little nut and bolt which holds the earth lead to the battery.  I had spent so long working on the left side of the bike, I had completely forgotten about the other side. Happy Days Eh?
