Author Topic: Do folk here Anneal Copper head washers?  (Read 4534 times)
« on: September 22, 2021, 06:32:53 PM »
Just wondering if it's worth me heating up my copper cylinder head washers to Anneal them or is this an extinct practice?
« Last Edit: September 22, 2021, 07:45:25 PM by Macabethiele (Ted) »
Offline ka-ja
  • ken
  • yoshi 460
Re: Do folk here Anneal Copper head washers?
« Reply #1 on: September 22, 2021, 08:24:29 PM »
Heat up until black, then dump in cold water-easy, I have a home made copper head gasket.
nice bike,nothing in the bank
« Reply #2 on: September 22, 2021, 10:29:23 PM »
I'm sure I've read on here before these washers are not actually cooper but are copper plated steel?
« Reply #3 on: September 22, 2021, 10:46:26 PM »
At £3.47 each I expect them to be Copper right through!
Mine are not even remotely magnetic - so definetely not steel plated  -  they are Copper - the staining on mine is Alluminium due to Galvanic corrosion effects from the cylinder head & nuts.
Alluminium & Iron sit above Copper in the periodic tabe so that fits with my theory unless someone can come up with another explaination.
« Last Edit: September 22, 2021, 11:23:25 PM by Macabethiele (Ted) »
amx1992
« Reply #4 on: September 22, 2021, 11:21:42 PM »
My original 400 ones were definitely copper plated steel, but I've replace them with solid copper ones so maybe someone has done the same in the past with yours Ted
« Reply #5 on: September 22, 2021, 11:26:08 PM »
Did you check if they were magnetic?
« Reply #6 on: September 23, 2021, 12:02:42 AM »
Mine were copper plated steel as well.
« Reply #7 on: September 23, 2021, 11:25:00 AM »
Cleary some are made from Copper plated steel then - would that be original fitting or an aftermarket fake item fited by PO's.
I have ordered 2 from DS as my two nuts down the plug holes had thin steel washers fitted - I hope the DS ones are Copper!
« Last Edit: September 23, 2021, 11:31:11 AM by Macabethiele (Ted) »
« Reply #8 on: September 23, 2021, 11:28:12 AM »
Original fitting Ted. We have had engines in for work that have never been apart before where some have just the copper ones fitted and others have the copper/ steel type fitted.
« Reply #9 on: September 23, 2021, 12:27:54 PM »
Ted, don't forget the two washers under the pillar nuts are dowty type.
« Reply #10 on: September 23, 2021, 01:24:08 PM »
I haven't slipped the head into place yet but thanks for the reminder - I bought the DS dowty ones in the end - tbh I've not worked out where the pillar nuts go yet - I'm thinking it will be obvious when the head is on.
Did you just grease the headgasket can't find the post that discussed this a few months back?
My head is a over the place today so I'm not fitting the head today - I get days when I'm not in the right frame of mind today is one of them so it's just reading up & viewing videos today.
oldchuffer
« Reply #11 on: September 23, 2021, 01:43:44 PM »
I know exactly what you mean Ted, if you're not in the right frame of mind theres just no point. I've been there, tomorrows another day.
« Reply #12 on: September 23, 2021, 02:41:38 PM »
Nice to know I'm not alone with that mindset - I blame my age I'm 73 - fully retired so optimistically still plenty of sand left in my hour glass of life.
Offline Moorey
« Reply #13 on: September 23, 2021, 03:36:01 PM »
 There my be plenty of sand but everyday the hole in the glass gets a little larger and the sand runs a little quicker.  ;)
Offline ka-ja
  • ken
  • yoshi 460
« Reply #14 on: September 23, 2021, 07:13:55 PM »
At my age, I forget to turn the hourglass over all the time.
