Author Topic: Rear disc conversion  (Read 47058 times)
Offline 400 Cafe Racer
Re: Rear disc conversion
« Reply #75 on: November 03, 2021, 10:20:37 PM »
Lovely chubley
Happy with that
Will need to make up the required wheel spacers nearer the time that will replace the round black and white areas you see at the moment
All really that is left to do is sort out a torque arm that fits between that hole in the hanger and the original fixed pint on the swing arm and improve the hub locking assembly as per the earlier post this morning which I see as a no brainier
As the wheel assembly design is almost complete and looks totally practical and all the main problems are solved I will next look to see how I can sort the rearsets to accept a master cylinder which will need my thinking cap on as it will need to look pleasing / factory like the rear disc assembly
Hope all are enjoying the posts so far
Best wishes Al
Hi Allan,
I've just caught up with the progress on your disc brake conversion, some lovely work going on there, nicely finished.
Looking at the mounting position of the underslung caliper, I just wondered what your thoughts are on potential water soaking of the pads from spray coming off the front wheel, it looks as though it could be in the line of fire. ?
What do you think ?
Regards
Retired Automotive Engineer   MIMI, MITRE, DMS, MCMI.
Latest     - 1989 CBR600F1 (FK) PC23
              - 1979 CB400/4  Cafe Racer - Parakeet Yellow
              - 1939 Velocette GTP 250 twin port Two stroke
1988-91 - Lamborghini Countach QV replica design and
                 build - 3000hr spare time project -Now Sold
In 1956 at 12yrs old and dirt tracking
              - 1937 Rudge 500 4 valve
              - 1940s Royal Enfield 225sv
              -  Ex WD Norton 500sv
Offline allankelly1
« Reply #76 on: November 03, 2021, 10:40:51 PM »
Yes I see what you mean, the set up is the roughly the same as the Cagiva Mito that I have copied that has a under slung caliper too.
Maybe slight lower but still under slung
Worse if it was an issue I could always add a subtle 3 d printed “deflector” mounted on my lower exhaust mount that sat in front of the caliper for extra protection from spray if I ever go out in the rain
Lastly pads are well hidden / shrouded inside the caliper due to it being an opposed piston unit rather than a sliding type with minimal gap for the disc thru the caliper body (about 1mm per side clearance between disc and caliper body)
Best wishes Al
« Last Edit: November 03, 2021, 11:02:13 PM by allankelly1 »
« Reply #77 on: November 05, 2021, 10:16:58 PM »
" if I ever go out in the rain" :D :D :D
Yes I know what you mean. !!!
The Delkevic looks very interesting.  Do you have any video footage so we can all hear that "music" through the rev range with the 400f on song. ??
Regards
Dennis ;) ;)
Offline allankelly1
« Reply #78 on: November 06, 2021, 08:16:11 AM »
Regards
Dennis ;) ;)
Will sort a YouTube link out for you
Offline allankelly1
« Reply #79 on: November 06, 2021, 08:40:01 AM »
The 3d printer you are using is giving really good results, can I ask what model it is and approx cost of running it?
Hi Oddjob
I am a greedy person
I have three in total, two ultimaker  2’s and bought my son last Xmas a Flashforge creator pro 2 that I borrow now and then (plus jump on his pc that has  Fusion 360  when I cannot use my SolidWorks pc)
The ultimakers tend to get used for big stuff like the disc carrier and my rd sale parts like replacement clock cases
and the flashforge for smaller stuff like the rear set stuff
And some nice dual extrusion/ colour parts too in ABS as the flash forge is good for fine detailed parts due to it using a smaller nozzle and filament and has a more controlled filament feed system
As for running costs,  other than upfront purchase and a few maintenance parts they run for free and at a good profit as they are always on the go making parts for eBay / FB and the Rd forums as shown below as a little home business as well as home projects too like the disc conversion
Best wishes Al
« Last Edit: November 06, 2021, 10:42:27 AM by allankelly1 »
Offline allankelly1
« Reply #80 on: November 06, 2021, 08:44:08 AM »
Regards
Dennis ;) ;)
Hi Dennis
Yes the Delkevic is a nice stainless system pipe and much cheaper than a yoshi pipe and British made
As for the sound
“Hear” you go
Not great videos but these two show how to be anti social
Well the little Honda is a stable mate to a hooligan RD350LC
https://youtu.be/npmpA5Oly24.
https://youtu.be/WqMzsvLBpJA
Best wishes Al
« Last Edit: November 06, 2021, 09:52:58 AM by allankelly1 »
« Reply #81 on: November 06, 2021, 10:53:19 AM »
That sound lovely! :o
Go on put the LC  on here, you nust have a sound track, aahh, go on...............please? 8)
Offline allankelly1
« Reply #82 on: November 06, 2021, 11:01:18 AM »
Hi Roo
Ok Just for you cos you did say please
Again is not great as it was taken on the first start up after the restoration but still should stir up 2t memories
https://youtube.com/shorts/Piqu9AfEeww?feature=share
Best wishes Al
« Reply #83 on: November 06, 2021, 11:24:41 AM »
I had goose pimples as soon as I heard it! cheers Al, youve made a reasonably young, old fart, very happy ;D ;D
Bet your garage smelt GORJUSS! ;D 8)
Offline allankelly1
« Reply #84 on: November 06, 2021, 11:33:46 AM »
You are welcome
« Reply #85 on: November 06, 2021, 05:12:34 PM »
Regards
Dennis ;) ;)
Hi Dennis
As for the sound
“Hear” you go
Best wishes Al
Hi Al,
Thanks for the "music" of the Delkevic. It sounds like a nice balance, not too obtrusive while cruising and releasing the full throaty character of the 400 Four on acceleration and upper rev band. Its the first chance I've had to hear the Delkevic on the 400 Four.
Cheers, much appreciated. ;) :)
Offline allankelly1
« Reply #86 on: November 06, 2021, 05:15:04 PM »
Regards
Dennis ;) ;)
Hi Dennis
As for the sound
“Hear” you go
Best wishes Al
Hi Al,
No problem and glad you like
Even the darling wife thinks it sounds awesome and prefers it to the RD
Best wishes Al
« Last Edit: November 06, 2021, 05:59:28 PM by allankelly1 »
Offline allankelly1
« Reply #87 on: November 07, 2021, 04:45:53 PM »
Hi Oddjob
There a a few free 3d packages out there and I think you can get Autodesk as a free trial package and if you have a “sibling” in full time education you can get the full package as a student for all the time they are in full time education as I did with Logan also as he now has an account once he leaves full time education he can get a license with up to 75% discount
Also it’s easy to learn and once you understand the principles of how a model is created you are away
For the flash forge don’t forget this is a dual unit thats a bit more pricy but all printers run free downloaded “slicer” software so the real outlay is the printer and a decent pc
Offline allankelly1
« Reply #88 on: November 07, 2021, 04:57:19 PM »
Yes I believe you can but I tend to measure and model up the original part and save it then modify the model after
If you are after sometime I would be willling to help out but as it a home hobby things do take time
Also don’t forget most time I am limited to only smaller items and my disc carrier was at my printers limit for size
Feel free to pm me if you want
Best wishes Al
Offline allankelly1
« Reply #89 on: November 07, 2021, 05:03:53 PM »
Ok back to topic
Just bought this
After a chat to the real “boss” an early Xmas prezzy for the rear disc conversion project
Original Dresda box swing arm (hence my other thread on interchangeability for swing arms)
Will need a bit of TLC but another non standard part for the old girl and will go well with the rear disc conversion
Only problem is this bike modification process has now started to become an obsession
Also now got my hose from Venhill so should be able to test fit this too to see if I got my hose length right
Catch up again soon and all have a good week
Best wishes and ride safe Al
« Last Edit: November 07, 2021, 05:13:06 PM by allankelly1 »
