Author Topic: 400 Four - PETROL GRADE CURIOSITY ?  (Read 12739 times)
Offline 400 Cafe Racer
« on: October 11, 2021, 07:25:36 PM »
Hi Guys,
I know there are many long time 400F members out there having run their bikes for yonks on various Petrols. I'm interested to see which type of unleaded (Regular) or (Super) you settled on and why. ?
Thanks ;)
Retired Automotive Engineer   MIMI, MITRE, DMS, MCMI.
Latest     - 1989 CBR600F1 (FK) PC23
              - 1979 CB400/4  Cafe Racer - Parakeet Yellow
              - 1939 Velocette GTP 250 twin port Two stroke
1988-91 - Lamborghini Countach QV replica design and
                 build - 3000hr spare time project -Now Sold
In 1956 at 12yrs old and dirt tracking
              - 1937 Rudge 500 4 valve
              - 1940s Royal Enfield 225sv
              -  Ex WD Norton 500sv
Offline allankelly1
Re: 400 Four - PETROL GRADE CURIOSITY ?
« Reply #1 on: October 11, 2021, 07:32:02 PM »
Super all the way
Don’t do many miles in a year so extra cost is worth it and at the moment super in most areas is ethanol free still
Also we know e5 does cause issue on some rubber and plastic parts on older bikes and modern plastic fuel tanks so why take the risk?
Best wishes Al
« Reply #2 on: October 11, 2021, 07:33:25 PM »
Always used supermarket regular in the past because it was cheap, now using Super Unleaded because its E5 (up to 5% Ethanol content), instead of the cheaper fuel which is now E10. I ended up with a bit of both a couple of weeks ago, so E7.5 😁😁😁😁 bike runs just fine on it but everything rubber on our bikes fuel systems is Viton anyway so I won't worry if I have to put the odd tank of E10 in.
« Last Edit: October 11, 2021, 07:37:11 PM by Nurse Julie »
« Reply #3 on: October 11, 2021, 08:21:51 PM »
Super all the way
Best wishes Al
Thanks Alan & Julie,
I fully agree with the thoughts on Ethanol.
Although Super is possibly not strictly necessary on terms of the 400 Compression Ratio, I'm assuming that some of the higher grade refining of the Super might have some beneficial effects in the burn process, that one may have noticed in use.
Has there been any apparent difference in your experience ?
Offline allankelly1
« Reply #4 on: October 11, 2021, 08:29:09 PM »
No as only run on super cannot comment but news on the street is e10 gives you less mpg in certain circumstances I presume due to a lower calorific rating due to the introduction of this bio fuel
I know some guys due to there low miles if e10 becomes the only supply are talking if  going over to avi gas as it E free and piston engine planes will be around along time after the government try to force / tax the ICE of the road due to their their underhanded tactics
Just is a bit more expensive
« Reply #5 on: October 11, 2021, 08:40:12 PM »
I have filled up on the odd occasion with Super unleaded in the past (pre all this Ethanol change) and to be honest, I never noticed any difference in performance or fuel economy. To be honest though, the 400/4 has such a small tank that I used to fill up 2 or 3 times on a days ride out with whichever fuel happened to be on the pump I stopped at.
« Reply #6 on: October 11, 2021, 08:42:52 PM »
When I used to rag the VFR up the strip up at 'Shaky' the times were always a bit better when there was super in the tank as opposed to the normal unleaded. Not sure if it's a chemical process thing or a mind thing but always filled up on the way in to make sure we had a full tank for the racing 8)
« Reply #7 on: October 11, 2021, 09:22:21 PM »
Hi Laverdaroo,
Thanks. Sounds then in your experience performance-wise with the Honda,  that there maybe some marginal benefits when pushing the engine at the limits.
Cheers ;)
Offline MCTID
« Reply #8 on: October 11, 2021, 09:29:46 PM »
http://amalcarb.co.uk/ethanol-fuels
Interesting article from the Burlen Fuel Systems Technical page....some years ago...but that's Burlen for you ! (I was reading it today when I bought some Amal Carb spares).
« Reply #9 on: October 11, 2021, 09:44:14 PM »
Realistically, yes but the times don't lie I guess. I was under the impression that it was down to available octane, higher rates etc but I'm no chemist.         One of the boys on here will more than likely be able to explain it or why I'm wrong but that was the gist of our thoughts at the time. Admitted, I wasn't even aware of the E5, E10 thing back then (5+years) ago,it was always assumed that the Super bit meant it was the better, sooper jooce to treat the bike to up the strip. I'm a bit older, fartier and fanatical now I own two older hondas' as well as the beloved VFR, she'll pretty much run on anything but the old girls I want to be treated as best as I can, as you do.
They've managed to live this long and I don't want to be the pillock to knacker them by using the wrong anything, fuel included. ::)
Offline allankelly1
« Reply #10 on: October 11, 2021, 09:54:06 PM »
I think the main problem is if you leave the bike standing for a length of time
Extended storage leads to the fuel absorbing water as its hydroscopic that then leads to rotted tanks as the water separates from the fuel and then sits in the bottom of the tank
Same happens in the carbs bowls that can rot brass ware etc
Also like it says seals need to be viton but is new to here so most older bikes are not e10 suitable due to older type rubber in use
Also hear that if left even in newer bikes if they are not used often the fuel will damage injectors as you cannot drain these for long term storage unlike good old carbs
I think for newer vehicles obviously the seals are compatible and the main thing is if it’s in regular use the fuel does  not remain for long in the tank and other critical areas of the fuel system
Also not god for my RD35C either
« Reply #11 on: October 11, 2021, 10:12:19 PM »
I've used super unleaded as soon as 5 star petrol went. Aside from it usually being ethanol free it's also lower in sulphur I believe plus some additatives in the mix. Likewise I use the ultimate diesel brands. I have consistently had marginal improvements in mpg I'm only talking 1-2 mpg on big engine vehicles that return 22-27 mpg. I also add Wynns dry fuel into our Merc that we only drive in the summer same when I had the Yamaha XJ900 - it somehow keeps the water molecules in suspension. Not an issue on the Merc as it has a plastic tank but on the paper thin Yamaha tank that I had to replace after about 5 years due to pin holes everywhere it  ensured the new tank lasted many more years until I sold it.
« Reply #12 on: October 12, 2021, 08:46:48 AM »
The grades currently available have obviously changed appraisal of them as E component is hot topic.
From a straightforward octane point of view,  none of these engines need or use a higher octane rating because of compression levels in their design.
To take advantage of raised octane fuel it would need to run increased compression and or need more advanced timing to gain advantage. Essentially it does nothing without modification as they don't approach the limits of fuel performance on the lower octane available 95 ?
"High performance" current injected engines that have compression and timing plus turbo etc optimised to run with raised octane fuels will scale back ultimate performance if used with a lower rated fuel. They can't analyse the fuel but they do have "knock" detection that senses the acoustic signature of cylinder detonation,  then pull back ignition advance and often increase fuel delivery to avoid catastrophic failure through heat accumulation in each cylinder.
Industry testing of true octane in fuel formation is ultimately verified by running a variable compression test cylinder engine.  It has the facility to keep increasing the compression on a run cycle until it starts to detonate, which confirms that specific formulation meets the stated rating to market the fuel at.
Offline Seabeowner
« Reply #13 on: October 12, 2021, 08:49:55 AM »
A bit like Julie, I have been using a bit of what I can get and noticed no difference. After E10 started I used super a couple of times, but will probably revert to every other fill. I'll probably drain the system for a few months over winter.
I knew the US had been using ethanol on and off for 50 years. Strange that only now they seem concerned about it and rant on about it.
I do wonder though if the corrosion found on the carbs (main jet tower particularly) that is seen on long stored US bikes may be a consequence.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
« Reply #14 on: October 12, 2021, 09:23:55 AM »
"I do wonder though if the corrosion found on the carbs (main jet tower particularly) that is seen on long stored US bikes may be a consequence."
Yes I'd see that the same as you,  the carbs being significantly zinc base matetial are easy meat in a sacrificed anode way. You just need the right chemical bath to propagate galvanic corrosion and away it will go.
There was a documentary recently that covered a service/spruce/maintenance refit of a north sea ferry in dry dock. They were changing the zinc sacrificial anodes on the hull (didn't even know they had them  ;D) great slabs of them that disappeared in protecting the hull and bronze propellers etc from the scavenging effects of running in sea water.
