Author Topic: 17255-246-000 Band type clip - any SS options ?  (Read 6277 times)
« on: October 15, 2021, 06:13:54 AM »
The four clips for the cylinder head carb mounts are priced at £8.70 each at DS is there a similar SS band clip available anywhere?
Links welcome please.
Of the four clips two of mine are somewhat out of shape does anyone use anything else that works & looks okay?
Re: 17255-246-000 Band type clip - any SS options ?
« Reply #1 on: October 15, 2021, 08:50:52 AM »
I thought someone on here had scourced some suitable in the right bandwidth so you may get that input.
But https://www.jubileeclips.co.uk/products/ these are a narrower band clip 7mm that could be used I think, although they show the toothed drive unlike smooth band types.
« Reply #2 on: October 15, 2021, 08:55:47 AM »
I can see these which have similar form to std but details are difficult to find, could give a lead though https://www.directindustry.com/prod/ideal-automotive-hose-clamps/product-67722-574329.html
« Reply #4 on: October 15, 2021, 10:31:32 AM »
I have found these they do a few sizes - I think I need a range 42-39 or similar hard to work out what they are - not so keen on Jubilee clamp type - not sure if they are too wide.
. https://hcl-clamping.co.uk/products/heavy-duty-hose-clamp-bolt-barrel-style-40-43mm-430ss
Update
They are too wide at 16 mm.
« Last Edit: October 15, 2021, 04:03:57 PM by Macabethiele (Ted) »
« Reply #5 on: October 15, 2021, 04:09:00 PM »
You could try these
https://www.ebay.co.uk/itm/Stainless-Steel-Hose-Clips-Pipe-Clamps-jubilee-type-304ss-British-Type-/265263590121?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l6249&mkrid=710-127635-2958-0
Hi Allan,
Not keen on Jubilee type clips tbh I'm hoping someone here has found something suitable in SS. I've done a bit of a straightening job on one of the clips but I fancy new in SS. Ted
These look a possibility even though they are Jubilee type? https://www.ebay.co.uk/itm/143540474102?ssPageName=STRK%3AMEBIDX%3AIT&var=442495312467&_trksid=p2060353.m2749.l2649
« Last Edit: October 15, 2021, 06:48:14 PM by Macabethiele (Ted) »
Offline Moorey
« Reply #6 on: October 16, 2021, 10:58:13 AM »
As you are in Derby have you tried  Derby Performance Hose in Swadlingcote. They may have something suitable or be able to point you in the right direction.
« Reply #7 on: October 16, 2021, 11:22:42 AM »
Interesting place the online ones look too wide but worth a call. Ted
« Reply #8 on: October 22, 2021, 03:31:20 PM »
In the end I have used these clips they fit a treat without too much 'spare' clip when you tighten them.
Black SS.
.https://www.ebay.co.uk/itm/143540474102?ssPageName=STRK%3AMEBIDX%3AIT&var=442495312467&_trksid=p2060353.m1438.l2649
« Reply #9 on: October 25, 2021, 10:04:33 PM »
Out of interest have you tried the following:
https://4into1.com/cart.php
Might be a long wait, but if you buy enough items even the postage cost is not too punitive.
