Author Topic: On a genuine CB400/4 rear mudguard how many number plate mounting holes?  (Read 11773 times)
My rear mudguard only has three holes for the rear number plate bracket I assume this isn't original as the grommets on the plate holder indicate four mounting points?
I can fit the unit by using the two upper rubber cushion mounts and the centre bolt hole on the bottom bracket as it was when I took it off.
Parts manual not much help as it appears to just show the upper mounts.
Is it for the USA model ?
Re: On a genuine CB400/4 rear mudguard how many number plate mounting holes?
« Reply #1 on: October 23, 2021, 05:47:51 PM »
If the parts book shows 2 different guards then probably
Offline allankelly1
« Reply #2 on: October 23, 2021, 06:51:42 PM »
Hi Ted
My original Uk plater holder had four bolt holes and so did the rear mudguard as you can see in the below picture
Hope this helps
Best wishes Al
« Reply #3 on: October 23, 2021, 09:03:09 PM »
The US ones were chromed whereas the GB ones were painted black
Offline allankelly1
« Reply #4 on: October 23, 2021, 09:39:29 PM »
Yes but both had four holes as I did a swap the one in the picture the other month to a chrome USA one
« Reply #5 on: October 23, 2021, 11:27:52 PM »
If the holes are in a triangular formation Ted then the guard is most likely a USA one. I do have a US number plate bracket around somewhere. As said they are chrome instead of black.
Yes they are in a triangular formation I have a chrome US type rear bracket but that also has 4 mounting points. I'll just use the three bolts with a rubber cushion on the lower bolt. The chrome is quite good on the mudguard so it's definetly been replaced by a PO.
« Reply #6 on: October 24, 2021, 06:51:26 AM »
I'll post a pic of the 3 hole bracket I have, it's not too bad.
It's occured to me that I could just drill a couple of holes and put a nut on the back?
Offline smoothoperator
« Reply #7 on: October 24, 2021, 06:45:54 PM »
My rear guard is ratty and has filler in it so I want to replace it. It has 4 mounting holes for the number plate bracket, the 2 lower ones being on a raised "hump", then 2 holes forward where it mounts onto the frame. I thought I had found a replacement with the one pictured below, but now I can see it is perhaps one for the US market. Any ideas on where to find a replacement welcome, I have been looking for a while now, so far to no avail. 2 pics of my guard also attached.
Steve
2017 Triumph Bonneville T100
Offline allankelly1
« Reply #8 on: October 24, 2021, 06:51:36 PM »
That’s intriguing
The American chrome plated one I have fitted from this supplier has three holes in the bottom so it fits both the four hole and three hole mudguards
« Last Edit: October 24, 2021, 06:54:23 PM by allankelly1 »
« Reply #9 on: October 25, 2021, 08:44:18 AM »
Yes I can confirm that mudguard is extremely tatty.
The 3 hole version that some American bikes got has the 3 holes quite close together but in a triangular pattern. The one Al posted a pic of is the 4 hole version, the 3 hole doesn’t get that forward stretching piece of metal with the 2 upper mounting holes.
I don’t think the 500 guard fits the 400 which is a shame as I have 3 or 4 decent ones including a NOS 3 hole version.
My original painted bracket has a centre hole so I'm going to drill it out a bit more to take a rubber mount  - the mudguard is too good to consider change never mind the cost. My spare chromed mount has no centre hole.
Offline wildtapholer
« Reply #10 on: October 25, 2021, 11:58:36 AM »
I got an mint rear mudguard and it came with the plastic part which I didn't need all for £68 from America and that was including import duties, it was the correct one with the 4 holes, I had to do a lot of searching but they come up now and again, totally transforms the rear end.
« Reply #11 on: October 25, 2021, 01:19:11 PM »
Nice rear fender you have there - what's with the chain guard - not chromed - is it a fully painted one ?
P.S. I've drilled out my mount and it fits a treat except I have no third collar insert - they seem to be unavailable.
« Reply #12 on: October 25, 2021, 01:23:21 PM »
Ted, Graham may have a spare insert, I'll ask him later.
« Reply #13 on: October 25, 2021, 01:50:20 PM »
If you could let me know where you got it from that would be great. I have found one at Bertrums, out of stock for £330. Then one in the USA for $49.66 delivered free to UK. If it looks too good to be true, it probably is, springs to mind:
https://www.ericmisey.com/index.php?main_page=product_info&products_id=549736
Steve
« Reply #14 on: October 25, 2021, 02:05:03 PM »
That's cheaper than a rechrome on my existing one & it has the correct four mounting holes. Is the customs duty plus overseas postage  $150 extra ? ;D
