Author Topic: Clutch mechanism  (Read 1109 times)
Offline Popstar
Clutch mechanism
« on: November 01, 2021, 01:01:23 PM »
I've discovered why the clutch isn't working on my project bike 1 the cable looks like it's been under artillery fire, 2 a small collar is missing where(see photo) the ball bearing sit's. I will have to see if Silvers have a pair. There is a rim on the outer edge which would be difficult to match.
Re: Clutch mechanism
« Reply #1 on: November 01, 2021, 01:23:51 PM »
The ball bearing goes in the hole, there is no collar
Offline Popstar
« Reply #2 on: November 01, 2021, 01:34:48 PM »
You are probably right but the collar dropped out when I started degreasing the mechanism.
Offline Popstar
« Reply #3 on: November 01, 2021, 01:56:56 PM »
Ok I will attempt to turn the large external adjuster screw later in appears to be seized up. Incidentally what diameter should the ball bearing be?
