Author Topic: The rebirth of Lazarus  (Read 217987 times)
Re: The rebirth of Lazarus
« Reply #285 on: September 10, 2023, 11:25:25 PM »
managed to put on youtube
https://www.youtube.com/watch?v=sOScVJ4W2fs
Little advise Mick, take a tappet cover of number 1 as well, to see you have oil on both sides.
Sounds like a sweet running engine.
Offline mickwinf
« Reply #286 on: September 20, 2023, 05:41:05 PM »
have been working on the carbs, all ok internally but doing a cosmetic externally. I have removed the operating rod, and is in very good condition unlike most. I need to sort the pin that stops the movement side to side and was thinking a suitable screw but only seems about 2mm. What do you guys use?
« Reply #287 on: September 20, 2023, 06:02:37 PM »
Ken told me he taps a thread in the hole then reduces a screw to suit.
I have an old carb air screw that might do the trick on mine - not sure of the thread.
Depending on how big the drill out is M4 looks about right on mine.
Offline mickwinf
« Reply #288 on: September 20, 2023, 06:34:40 PM »
Carb air screw is a possibility but maybe a bit big.
« Reply #289 on: September 20, 2023, 07:27:33 PM »
Cut down to suit?
« Reply #290 on: September 20, 2023, 07:47:31 PM »
I use these Mick.
https://www.ebay.co.uk/itm/313583380550?var=612402648482 M5 10mm.
The end is still too big to fit into the slot on the shaft so I fit it into a drill and spin it up whilst holding a file against the end, as they are brass they file down quite easily. I keep checking to see when it fits inside the slot.
Offline mickwinf
« Reply #291 on: September 30, 2023, 04:43:42 PM »
slow but steady progress, carbs are all looking good, I used a 3mm screw with the end filed down as per kens advice and all fitted with rubbers etc all standard although ordered a couple of new clamps to be fitted later. Seat is now on, it is an original in very good condition that I got from ebay, a guy was selling it with some carbs and a front mudguard so I bid him for all three together and he accepted my price, I reckon if he left the auction running he would have made more. The mudguard is an original 1970s one with holes for a front number plate, in good nick apart from some corrosion under a stay but not visible. I did re-chrome the seat strap fittings as I didnt like the repro ones I had before, although I did buy a set to get some new screws and they look a better shape now. Also needed a new plunger and a seat lock, both genuine items. will put some pics up from my phone.
Offline mickwinf
« Reply #292 on: September 30, 2023, 04:46:46 PM »
Here are some pics
Offline mickwinf
« Reply #293 on: September 30, 2023, 04:50:20 PM »
More, under seat and carbs before restoration and the original ones.
« Last Edit: September 30, 2023, 04:52:52 PM by mickwinf »
« Reply #294 on: September 30, 2023, 04:55:13 PM »
Looking back to the start you must be chuffed to bits with the build. 👍👍👍
« Reply #295 on: September 30, 2023, 05:30:55 PM »
Get in, we’ll done Mick, superb news. Hats off to you mate, what a transformation!
« Reply #296 on: September 30, 2023, 09:20:26 PM »
Those carb to manifold rubbers don't look right Mick.
I did some on Grommitdogs bike earlier this year. When the engine was revved you could see them pulsing and the carbs moving back and too as they did so. The weight of the carbs also bend them down. Genuine ones don't look like that, they are sort of plastic looking and will support the carbs with no problem. Are they DS replacements?
If you need some I have loads spare somewhere.
If that's the clutch cable going over the throttle cables that's routed wrong and will cause problems.
« Last Edit: September 30, 2023, 09:25:11 PM by Oddjob »
Offline mickwinf
« Reply #297 on: October 01, 2023, 11:18:13 AM »
Hi Ken, I think the rubbers are original ones as I didn't use DS ones this time. The clutch cable is the wrong one supplied as far too long so probably US style high handle bars. The cable I got from silvers was chap and caused sticking clutch so not keen on getting another. Not sure where to source another.
Offline mickwinf
« Reply #298 on: October 18, 2023, 03:49:15 PM »
came to fit the repro top brake hose and it turns out to be the long version for US style bars and Silvers dont do the shorter one. any suggestions for a supplier, i would prefer the rubber original type.
« Reply #299 on: October 18, 2023, 04:13:42 PM »
Try Wemoto or Burtons Bike Bits. HEL do a black braided hose that looks like a period one.
