Project Board
The rebirth of Lazarus
27
28
29
Topic: The rebirth of Lazarus (Read 217753 times)
davidcumbria
Such great knowledge and support on here 👍
SOHC Expert
Re: The rebirth of Lazarus
Reply #405 on:
April 21, 2024, 07:38:03 AM »
Mine are middle notch which is what the often posted chart says.
500/4 in 79. No bikes for 30 years. 750/4 in 2013, 550/4 in 2023. Also own R1100GS, RD350LC YPVS , Yamaha fazer 600, Yamaha XT250, BmwR80 , HondaVT1300, Royal Alloy GT125.
mickwinf
Reply #406 on:
April 21, 2024, 09:14:29 AM »
OK will try them in centre groove, thanks all. I must admit I am not enjoying this snagging process as I have not been able to have a proper ride yet. Hopefully get there soon.
mickwinf
Reply #407 on:
May 11, 2024, 03:39:38 PM »
had a little time today as Luna the dog is recovering well from her operation and can be left unsupervised for a while. I decided to replace the clutch plates with new EBC items and also changed the springs for some H/D ones I had. Snag is I thought I had a spare gasket but that is a 550 and is slightly different. the old one would probably go again but dont want to do the job again. I have had the carbs apart and put the needle clip in the centre groove and made sure things were clean in there, once the clutch is back together will try it out and report back.
mickwinf
Reply #408 on:
May 19, 2024, 06:22:16 PM »
had a chance to try a ride, only about 10 miles but a big improvement on before. the big flat spot is much reduced since changing the needle clip position and the clutch also feels better. A weird thing happens though when i open the throttle to accelerate It sometimes snatches as if i had momentarily pulled the clutch in, strange, and carbs still need setting better as get a hanging idle sometimes. At least I had an enjoyable ride with a reasonable chance of getting home with no unplanned stops!
SteveD CB500K0
Administrator
Ride on the Steel Breeze...
Reply #409 on:
May 23, 2024, 07:02:27 PM »
Mine used to do that in third gear Mick.
It was a worn central dog in the gearbox.
mickwinf
Reply #410 on:
May 23, 2024, 11:00:02 PM »
hope its not that Steve, did lots of work on gearbox.
mickwinf
Reply #411 on:
May 28, 2024, 11:21:03 PM »
Lazarus continues to frustrate me and resist his rebirth.started running on 3 cyls, and after swapping plugs etc with no effect I decided it must be a blockage in no 2 carb. So carbs off again and pilot jet had a blockage, then after cleaning carbs back on. Now running on two cyls! Turns out the low tension wire has broken off the coil. A member of our fine forum Simon has offered to do the Ash fix on some spare coils for me so hope to be back running soon.
mickwinf
Reply #412 on:
June 19, 2024, 02:51:06 PM »
After Teds thread on losing enthusiasm I had a bit of a rethink and took lazarus out for a ride, the first one since i re-cleaned the carbs and fixed the coil. Running much better although still a bit of hesitation off idle. Came home and weakened the mixture a bit more and again a bit more improvement. checked the plug colour and still sooty, but getting lighter on each adjustment. The clutch still not quite there, not sure if adjustment is wrong or some other fault. Tickover is a bit odd, sometimes a slight hanging throttle and sometimes cuts out when coming to a stop. oh and no 3 cyl runs slightly hotter than the other three. But did a few miles and enjoyed the ride.
McCabe-Thiele (Ted)
Reply #413 on:
June 19, 2024, 03:18:11 PM »
Do you have the correct 500 air screws with the holes in them?
As you will know turning the screws ant-clockwise will weaken the mixture through the idle and low speed range.
If by any chance you have the 550 air screws (solid brass with a cut off nose) its only a 1/4 turn that is about equivalent to a full turn and a half or so of the 500 screws.
Last Edit: July 21, 2024, 07:48:04 PM by McCabe-Thiele (Ted)
Link to my full restoration
mickwinf
Reply #414 on:
July 21, 2024, 04:29:12 PM »
back with Lazarus again, as reported before the two main things were a flat spot off idle and a clutch slip problem. I put the needles in the centre groove and made a big difference, each subsequent adjustment makes a slight improvement so getting there except for a slight hanging idle. The clutch was doing my head in, as all seemed good with new plates etc, but continued to slip. It felt as if i had the clutch slightly held in, so checked the operating mech, the spiral thread thingy. It felt like it was catching and not returning as it should. the cable is a new oem item with the plastic liner, this is the second one that i have had problems with and found the liner was damaged where it joins the lever at the handlebars. I carefully cut the bad bit off and lubricated with silicone grease, also replaced the spiral holder with a spare. result is I have just been on a 20 mile ride and come back with a big grin and hope a little more fettling should get him 100%
Reply #415 on:
July 21, 2024, 06:18:27 PM »
That mechanism was not the best when new, now 50 yrs on its just damn awkward!
Nurse Julie
Reply #416 on:
July 21, 2024, 08:24:18 PM »
Well done Mick.
mickwinf
Reply #417 on:
August 07, 2024, 02:31:11 PM »
not had a lot of time with bike, but had a tinker with carbs again, synced them and tweaked air screws. still not quite right. My question is the idle screw adjusters are now 2 full turns out and flush with the edge of the casting they fit into. If I adjust any further out they would maybe fall out? have I reached the end of adjustment and if so should I fit smaller idle jets? carbs are 627s 100 main jet 40 idle jet. also front brake screams like a banshee although feels good. Once I am satisfied he is running ok then I will treat him to the new 4/4 exhausts sitting in my bedroom!
mickwinf
Reply #418 on:
August 07, 2024, 02:33:32 PM »
oh forgot to say, the screws are the ones with the hole in the end as per Teds post.
McCabe-Thiele (Ted)
Reply #419 on:
August 07, 2024, 02:52:12 PM »
I'm a novice here - fitting 38 jets ought to be good or would the solid 550 type screw be easier and let in more air for fewer turns?
Bryan or Ken will know for sure.
27
28
29
Project Board
