Author Topic: Original front pipe question.  (Read 2300 times)
« on: November 07, 2021, 03:28:42 PM »
My bike came with the original 4 into1 front pipe - the bike had a newish Motad system fitted. If I decide to fit the original can you till replace the filter without having to remove the front pipes?
Re: Original front pipe question.
« Reply #1 on: November 07, 2021, 03:55:11 PM »
Yes. Original downpipes allow filter change. 👍
« Reply #2 on: November 08, 2021, 05:03:20 PM »
Good to hear I'm minded to fit the original front pipes they are in reasonably good condition and loook so cool. Seen a rear silencer that looks good value provided the pipe size & mounting points are right  - made in the UK as well.
Perhaps a member here has used them?
https://www.ebay.co.uk/itm/334060950977?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
« Last Edit: November 08, 2021, 06:10:22 PM by Macabethiele (Ted) »
« Reply #3 on: November 09, 2021, 09:45:13 AM »
That's probably the same silencer as DSS uses on his replicas. The company stocking them are very good to deal with, they normally have a stand at Kempton Autojumble.
« Reply #4 on: November 09, 2021, 10:04:19 AM »
I remember a report that the captive nuts neede taping out dueto flash chrome but that is asmall point
« Reply #5 on: November 09, 2021, 10:45:32 AM »
bsa111 who are listing that silencer, somehow had a tie up with Brituro, who went skint. I don't know if they took on the jigs and started reproducing them or what. A couple of years back, when you typed in Brituro to Google, the links all ended up at bsa111. That one advertised looks identical to the Brituro fitted to my 400/4 but the original Brituro had a number stamped on the collector box end collar.
