Author Topic: Clutch service limits CB500K1  (Read 3686 times)
Offline Popstar
« on: November 07, 2021, 05:25:43 PM »
Would forum members please be good enough to checkout to photos I have attached to this thread. I am interested in service limits and plate quantities, I have purchased a new clutch cable as the one fitted took two hands to pull in,however when I inspected it no snagging was evident, does this early model have a paticular issue with the clutch?
« Last Edit: November 07, 2021, 05:32:11 PM by Popstar »
Re: Clutch service limits CB500K1
« Reply #1 on: November 07, 2021, 05:27:54 PM »
The clutch push rod can be a big issue as they snap due to the chain hitting it and worm drive can also break up. Also not being shimmed correctly can cause issues.
« Last Edit: November 07, 2021, 05:30:23 PM by Nurse Julie »
Offline Popstar
« Reply #2 on: November 07, 2021, 05:30:45 PM »
The rod appears to be OK in terms of damage however I am not sure of the length (see photo) .
« Reply #3 on: November 07, 2021, 05:39:29 PM »
Hang on a sec and I will measure a new one.
« Reply #4 on: November 07, 2021, 05:46:35 PM »
Is the ball bearing the correct size?
« Reply #5 on: November 07, 2021, 06:00:53 PM »
One problem is people insist on lubing the Honda cables and genuine Honda cables have the outer nylon lined and the inner coated with what looks like rubber, oil type lubes swells both bits and makes them incredibly tight to pull
Offline Popstar
« Reply #6 on: November 07, 2021, 06:05:02 PM »
Ball bearing is correct size yes.
Offline Seabeowner
« Reply #7 on: November 07, 2021, 07:00:55 PM »
According to manual, spring length new is 31.9 and service limit 30.5. Just checked a couple of springs that came out of spare engine and they are about 30.9. (But no guarantees they are original as it had a strange mixture of plates and I have never run it) Also bear in mind Honda manuals have a few mistakes.
The 500 clutch is certainly heavier than 550s. The design came from the 450 and parts of the original concept hark back to much smaller bikes that Honda made.
Plates new are stated at 3.3mm
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
Offline Popstar
« Reply #8 on: November 07, 2021, 07:34:46 PM »
The bike is a former US import,I have read were they liked to put stronger springs in clutches in the states so that could account for the extra spring length, are the plate quantities correct metal/fibre?
