Author Topic: alternator wires covering  (Read 4518 times)
Offline billdn
« on: November 12, 2021, 02:45:03 PM »
I suspected a damaged wire and slit this covering open, but thankfully no damage, but how to replace/make good - I suspect it gets hot hence the woven type sleeve so 2 questions :-
a) cover with heat shrink - don't think its suitable tbh.
b) Vehicle wiring products do similar on their site , use that?
c) insulation tape- only kidding!
I know don't do that again but was only looking honest, the field core wires covering is also bit frayed so possibly change that also.
Re: alternator wires covering
« Reply #1 on: November 12, 2021, 03:29:05 PM »
I seem to recall its called systoflex, probably wrong spelling
Offline billdn
« Reply #2 on: November 12, 2021, 05:46:45 PM »
Right spelling Bryan, but doesn't appear to be made , I'll  try Vehicle Wiring Products woven sleeving looks similar.
« Reply #3 on: November 12, 2021, 06:40:12 PM »
what about the heat proof tape they use when powder coating, that's a secure wrap and is heat resistant?
Just a thought and a bit of a guess but it seems to be good stuff and used in numerous applications........
« Reply #4 on: November 12, 2021, 06:47:00 PM »
Well last time i used it was in 75 on a 3ph turbo alternator just off Saigon
« Reply #5 on: November 12, 2021, 06:52:19 PM »
RS PRO Braided Acrylic Fibreglass Black Cable Sleeve, 2mm Diameter, 5m Length
Offline billdn
« Reply #6 on: November 12, 2021, 07:44:28 PM »
Spotted that one Bryan, anyone need spare 4m 🤣
Offline SteveW
« Reply #7 on: November 13, 2021, 09:22:12 AM »
Sounds like a urine infection  :D
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
« Reply #8 on: November 13, 2021, 10:45:17 AM »
I need a couple of metres.
Offline AndyD
« Reply #9 on: November 13, 2021, 11:11:46 AM »
Is the stuff on AES any good for this?
https://www.autoelectricsupplies.co.uk/product/342/category/66
Cheers,
Andy
Offline Deano400
« Reply #10 on: November 13, 2021, 11:14:24 AM »
« Reply #11 on: November 13, 2021, 06:53:43 PM »
Offline Deano400
« Reply #12 on: November 14, 2021, 10:56:16 AM »
Hi Phil.
Can't remember what I bought but measuring what I have in the garage it appears to be 6mm and 8mm dia. I used it on a 400/4, the 6mm for the two wires from the points and the 8mm for the 3 wires on the alternator side. I used a bit of tape on the ends to secure the the sleeving and than covered the tape with black heat shrink to finish it off.
Offline ST1100
« Reply #13 on: November 14, 2021, 12:54:20 PM »
STOC #637
