Author Topic: CB400four o-ring size sprocket shaft  (Read 2925 times)
Offline eem46
« on: November 15, 2021, 12:55:18 PM »
Dear All, Honda doesnt show the part/part number of this hidden o-ring under the metal sleeve, which goes into the crankcase seal of the chain sprocket axle.
Do you maybe now the size? My own quick check is 22mm inside and 2 mm thick
Offline TrickyMicky
Re: CB400four o-ring size sprocket shaft
« Reply #1 on: November 15, 2021, 02:29:57 PM »
If you are sure of the measurements, might be worth giving these people a try. I've used them for O rings on an old 160 Honda. Very prompt service and a reasonable price if you're stuck.
Offline Seabeowner
« Reply #2 on: November 15, 2021, 07:19:08 PM »
Strange that it is not shown on the 400. On the 500 it is 91306703000 and marked 24.5mm but don't know the c/s.
Gasket sets often include it and wondered where it went as never needed one.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
Offline eem46
« Reply #3 on: November 15, 2021, 07:46:25 PM »
Thank for the info, I found a company in Holland who sells all orings sizes, including viton.
Honda sees it as an complete part #141
Offline ka-ja
  • ken
  • yoshi 460
« Reply #4 on: November 15, 2021, 07:50:55 PM »
A dealer told me years ago that the shaft/sealing bush/bearing was not a strip down item and you bought the shaft with bearing and the sealing sleeve pre-assembled, maybe that is why the o ring is not listed, I replaced the bearing in the eighties, and the sleeve was hard to remove, but was not a tight fit on replacing, I secured it with a couple of tack welds.
« Last Edit: November 15, 2021, 07:52:37 PM by ka-ja »
nice bike,nothing in the bank
