Author Topic: Neutral Switch O ring  (Read 3200 times)
Offline smoothoperator
« on: December 03, 2021, 06:25:17 PM »
Does anyone know the size of the O ring fitted to the neutral switch on the 400F?
Steve
2017 Triumph Bonneville T100
Offline TrickyMicky
Re: Neutral Switch O ring
« Reply #1 on: December 03, 2021, 11:20:26 PM »
Can't help with dimensions, but if you're stuck, David Silver has some in his USA warehouse.
  Part No. 35751 333 003
  I've ordered a few parts from him for a USA spec. CL160 I'm playing with, and delivery was a lot quicker than what I'd expected, between 1 & 2 weeks, and no extra costs.
« Reply #2 on: December 04, 2021, 10:04:37 AM »
Thanks for that Tricky. At £3.97 I thought I might be able to save a few bob if I could find an alternative. Not a lot in the great scheme of things. I'm at the part of the build where lots of these little odds and sods crop up and I think I get meaner/wiser with the pennies.
Steve
« Reply #3 on: December 04, 2021, 10:31:54 AM »
Ive a spare switch in the shed and due out there this arvo, do you need a measurement once I get out there?
« Reply #4 on: December 04, 2021, 11:00:33 AM »
Thanks Roo but I have measured mine at 11.5 mm in the ring groove and 13.7 mm outer diameter. So it would be a fair question as to why I asking for the dimensions! Well the short answer is that whilst I know the switch dimensions, I'm not an engineer so I don't assume that I need let's say an 11 mm x 1.5 mm O ring, (pack of loads for £8 on ebay). I think I'll stop here, just found a pack of 11.5 x 1.5  viton rings for £1.40 free post on ebay! - can even order a single one!
Steve
« Reply #5 on: December 04, 2021, 12:37:17 PM »
More likely11x2
« Reply #6 on: December 04, 2021, 01:54:22 PM »
cool, no bother, as longnas youre on it 8)
