Author Topic: Another carb query  (Read 4256 times)
Offline toucheturtle
Another carb query
« on: April 03, 2010, 05:06:39 PM »
Hi,
I had my carbs rebuilt a couple of months ago but they've developed a fault. I have a CB500 K1, on first starting it wont tick over on or off choke without being revved. Once warm it runs fine and ticks over happily at 1500rpm but as you continue to ride it the idle tick over increases up to 3000rpm and has to be adjusted down.
Re: Another carb query
« Reply #1 on: April 05, 2010, 07:55:44 AM »
Normal, you should set the tockover to about 1150 when HOT and hang the slide when cold
NB THE CHOKE DOES NOT INCREASE THE TICKOVER LIKE ON A CAR
Offline totty
« Reply #2 on: April 05, 2010, 10:32:48 AM »
check the pipes heat up evenly, when mine did this it was a blocked pilot.
« Reply #3 on: April 05, 2010, 10:05:34 PM »
Hi Bryanj,
What do you mean when you say hang the slide when cold.
Cheers, Andy
« Reply #4 on: April 06, 2010, 03:34:13 AM »
Hold the throttle open a bit or "hang the carb slide on the cable", comes from Brit days
Offline Yoshi823
  • Biker to the bone...
« Reply #5 on: April 06, 2010, 10:14:23 AM »
Having owned a 550F1 as well as the K3 & F2, I found that the F models needed a bit of help when on choke as Brian has said...but the K3 had a cam arrangement on the carbs that when the remote choke cable was operated it lifted the slides slightly so that there was a faster tickover when on full choke...useful while pulling your gloves on. But the 'F' models didn't have this choke cam...& neither did the 500K models.
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
« Reply #6 on: April 06, 2010, 10:15:44 AM »
Thanks for that Bryanj
