Author Topic: 1975 CB750 P2 Police Bike  (Read 67643 times)
Re: 1975 CB750 P2 Police Bike
« Reply #75 on: March 12, 2022, 07:34:46 PM »
Amazing quality of work going on there James👍.
I bet that siren drive wore through the sidewall of the tyre quickly when in use.
« Reply #76 on: March 14, 2022, 08:38:12 PM »
Amazing quality of work going on there James.
Thanks Dave. Yeah I bet the sidewall took a hammering ha ha..
« Reply #77 on: March 14, 2022, 08:40:42 PM »
Further progress on the CB750P today.
Exhausts fitted, rear crash guard hoops fitted, front fender stays fitted, rear fender extender fitted, front brake assembly fitted.
Also test fitted the front engine guards.
Rear siren roller drive retaining spring fitted. Will re-engineer the drive bracket at a later date once the bike is finished.
Tomorrows job is to wet-sand the fuel tank and apply the decals before returning to the painter to clear.
« Reply #78 on: March 14, 2022, 08:45:13 PM »
Simply stunning, loving this apart from seriously needing to up my game ;D
« Reply #79 on: March 14, 2022, 08:45:26 PM »
Absolutely cracking job. Very interesting build.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #80 on: March 15, 2022, 11:06:51 AM »
…how is the siren engaged James? Could this be achieved at speed? What min speed is necessary for it to work?
Honestly it seems a bit Heath-Robinson given the era, I’d have expected a power off-take from the engine …. eg the SOHC, or perhaps electrical + uprated ALT. Intriguing! (Tho’ it’s apparent a very high siren drive RPM was necessary given the massive ‘gearing’…. bet the top speed bled off pretty quickly 😂)
« Reply #81 on: March 15, 2022, 11:54:38 AM »
You have a brilliant looking build there it's looking factory fresh!
Makes mine feel a tad Heath Robinson by comparison - never realised how good a white bike could look.
« Reply #82 on: March 15, 2022, 04:33:29 PM »
Having seen it mentioned in two consecutive posts, there will be young people out there wondering what or who the hell was Heath-Robinson?
Lovely build as expected, most of us don't have a load of NOS parts stashed away for future use, especially a genuine exhaust set, or a Police speedo for that matter.
« Reply #83 on: March 16, 2022, 09:31:50 PM »
Thanks for the encouraging words / comments / feedback.
With the words ‘Heath Robinson’ ringing in my ears, I had a spare hour over lunch so decided to mock-up a replacement for the siren drive to test-fit before committing  the design to metal.
I’m lucky to have access to a ‘fablab’ in the studios where my business is now based, including an array of ‘Prusa’ 3D printers. I was trained how to use the printers last week, and this was a fairly ambitious ‘second print’ so I was fully expecting it to go ‘tits up’.
So working from the existing siren bracket and some ‘guesstimated’ dimensions from photos found online of the ‘correct’ 750 bracket (turns out mine is for a 500/4 police bike) I designed up the unit in 3D (using Fusion360) before exporting an STL file, ‘slicing’ it up in preparation for 3D printing, outputting the G-code and then 3D printing in PLA.
Having removed the support material, have to say I’m pretty chuffed with the result.
However, the rule of ‘measure twice, cut once’ applies here (well actually check your design twice, 3D print once lol).In my haste I managed to place the design for the return spring hole on the wrong side (realised after printing). So I’ve adjusted the design and set one to print overnight.
Will test fit tomorrow evening to see if it’s a better solution than the 500/4 ‘bent arm’ design, before manufacturing it.
« Reply #84 on: March 16, 2022, 09:32:07 PM »
With the words ‘Heath Robinson’ ringing in my ears, I had a spare hour over lunch so decided to mock-up a replacement arm for the siren roller-drive to test-fit before committing  the design to metal.
There were actually 2 machines free at lunchtime, so I ‘hedged my bets’ and set off two of the machines printing (one in black PLA and one in Grey PLA). That’s why the ‘finished’ part is black - that was one of the two prints..both successful (apart from the design cock-up - see below).
Dismantled 500/4 ‘bent arm’ unit:
Reference photo of correct 750 unit..
Designed up in Fusion360 (note the wrong spring hole position ha ha)
Mid-way through the print:
The printed part - even the M8 x 1.25 thread was a decent fit for the nut.
The ‘printed’ prototype, with the original roller test-fitted/assembled:
The ‘revised’ arm design, with correct spring hole position (still can’t believe I missed it first time ha ha).
« Last Edit: March 16, 2022, 09:53:59 PM by JamesH »
« Reply #85 on: March 16, 2022, 10:37:04 PM »
Had to Google quite a few terms in that James but think I get the idea. Before that I thought that PLA was Peoples Liberation Army  ;D
Looking good.
« Reply #86 on: March 16, 2022, 10:39:16 PM »
Looking good.
Ha ha you just solved a mystery for me Ash - I posted the above up on Facebook and the post was automatically removed from the Facebook group I posted it in. I guess the PLA auto-censor must have kicked-in..
« Reply #87 on: March 18, 2022, 12:55:28 PM »
So, the 3D printed arm did the trick. Perfect alignment of the roller now, so I can go ahead and get get this manufactured now…
« Reply #88 on: March 18, 2022, 01:34:44 PM »
Fantastic Job James. I admire people who can use the modern tech to make parts, I've just progressed to making cardboard templates!
Amazed who you are progressing with this build so quickly, I have spent the morning building the Triton and all I have managed to do is remove the rear engine plate and fit a Morgo oil filter although the oil lines are still to fit!
« Reply #89 on: March 18, 2022, 01:36:08 PM »
I find sleep is over-rated Dave ha ha.
