Author Topic: Front axle potential problem?  (Read 6569 times)
Online McCabe-Thiele (Ted)
Re: Front axle potential problem?
« Reply #15 on: December 21, 2021, 06:15:30 PM »
A bit of an update - I've tried the original bolts and it's not an improvement.
Next I'm going to fit a different drive plate as I have one - thought occurs to me that the original rubber centre section might be the cause of pushing things off centre. As I have a spare one that's a no cost option.
Second option is to try a different drive casing / hub  unit, last option as it's the most expensive - fit new axle & nut.
Update: I have a drive untit/hub on it's way as insurance - found what might be a reasonable condition one for less than £24 inc postage.
« Last Edit: December 22, 2021, 04:40:55 PM by McCabe-Thiele (Ted) »
« Reply #16 on: January 01, 2022, 08:43:55 AM »
Yesterday I fitted a used replacement speedometer drive plate & worm drive hub.
This has fixed my chrome ring binding issue - pretty sure it's the drive plate that was the problem. The rubberised centre section I think was causing the issue. The clearance gap between the chrome ring & the hub is much more even so am happy with the outcome.
