Author Topic: I'm loosing my numeracy mind on valve clearances!!  (Read 2265 times)
« on: December 17, 2021, 04:40:54 PM »
Failing to Plan is Planning to Fail - so whislt I'm messing with my front wheel in the daytime - my mind started to wander into valve clearances come bedtime.
I've looked in the manual - it gives Inlet & Exhuast for a 400 engine as 0.05mm or 0.002 ". I haven't spotted the words Hot or Cold engine anywhere.
My feeler gauges - I have imperial & metric are probably 50 & 30 years old respectively - I can't read any numbers due to deterioration over the decades except on the never used thick ones - note to self buy replacements.
I thought okay I understand 0.002" it's two thousandths of an inch in words - I'm used to bigger gaps like 12 thousandths on a car. So 0.002" is the thickness of some medium grade paper.
Stupidly I then said to myself naaah it's got to be 20 thou surely - then I looked at the decimal and though no 20 thou is actualy 2 hundreths of an inch.
At 0.002" I'm amazed you can hear a tappet rattle at all - its close to naff all as gaps go.
Does this look suitable or will it be too wide ?
https://www.ebay.co.uk/itm/114686642402?hash=item1ab3db48e2:g:UH8AAOSwUylgKybE
Offline smoothoperator
Re: I'm loosing my numeracy mind on valve clearances!!
« Reply #1 on: December 17, 2021, 05:17:56 PM »
I'm pretty sure valve clearance applies to cold engine Ted. My old feeler gauges have fortunately kept their markings. I used the method of tightening the adjusters with the 3 thou gauge in, then when you remove the feeler gauge it is actually closest to 2 thou. I've done this on cars and bikes before and found that they tend to get too small a gap when tightened using the actual gap gauge, if this makes sense. Either way I wouldn't buy just a single gauge as you get a better measure of the gap by trying 1 thou up and 1 thou down to "feel" the gap. It does feel weird setting such a small gap.
Steve
2017 Triumph Bonneville T100
« Reply #2 on: December 17, 2021, 06:03:21 PM »
The pitch of the thread on the adjuster is 1mm so 1 full turn is 40 thou 1/8 of a turn is 4 thou
« Reply #3 on: December 17, 2021, 07:54:00 PM »
To confirm Ted, it's 2 thou cold.
« Reply #4 on: December 17, 2021, 09:28:48 PM »
Thanks for that Steve, Ken & Bryan.
« Last Edit: December 17, 2021, 09:40:57 PM by McCabe-Thiele (Ted) »
« Reply #5 on: December 18, 2021, 10:44:00 AM »
Ted get yourself some 2 thou shim steel online. You can then cut and bend a piece to suit. Makes the job way easier and you get enough on the length to make about 6.
