Author Topic: Electronic ignition with fixed advance.  (Read 3272 times)
« on: December 21, 2021, 10:59:17 PM »
Hi, I am puzzled slightly on refitting the dyna s electronic ignition that came with the bike, I noticed that there is a pin that the rotor slot locates onto along with the weight lobes that prevents the rotors returning to unadvanced position. I could easy remove it but it was probably put there for a reason. I can post pics but I actually stripped the unit and is sitting in thinners overnight because it was covered in some sort of grey paint overspray.
Re: Electronic ignition with fixed advance.
« Reply #1 on: December 21, 2021, 11:18:01 PM »
Does this help at all  - I have the Dynatek system - the mechanical advance mechanism is fully retained on mine - the electronic set up just replaces the points system.
https://howtomotorcyclerepair.com/dynaignition/
« Last Edit: December 21, 2021, 11:27:52 PM by McCabe-Thiele (Ted) »
« Reply #2 on: December 22, 2021, 07:10:48 AM »
Thanks Ted, that’s a very clear video on how to set up ignition system. This and other videos I have seen all retain the original advance mech. I don’t think mine is the original Part.
« Last Edit: December 22, 2021, 09:57:23 AM by Johnny4428 »
« Reply #3 on: December 22, 2021, 10:00:25 AM »
The other thing is the pin is preventing the rotor part seating properly. Should I remove the pin to have the advancer working as it should?
« Reply #4 on: December 22, 2021, 10:11:34 AM »
From their own information, Dyna S uses original bike factory advance and makes a point of stating that'll give no specification change from factory in that respect.  The trigger is magnetic in comparison to a "lumpy" cam with points, but should still advance and retard as usual as far as can  be seen from setup etc.
Looks like the pin obstruction isn't required to me. Boyer electronic for example specifically deletes the original advance retard mechanism for their fully electronic systems with that function handled internal and with switching logic entirely. It actually sets the ignition physically at full advance and pulls it back to retarded based on rpm register program within the unit, but nearly all other systems don't do this.
« Reply #5 on: December 22, 2021, 11:08:32 AM »
Thanks for your logic! There was nothing about this bike when I bought it that suggested there there had been anyone competent near it, so many bodges and defects, that’s why I have to question everything I’m not sure about and rely on the good knowledge of the good people of this forum. Cheers!
« Reply #6 on: January 01, 2022, 05:21:32 PM »
Found this whilst looking for something else FOI "Johnny4428" it loads as a chrome extension from https://classiccycles.org/1852/3701.html
Right click and choose load chrome extension
chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/viewer.html?pdfurl=https%3A%2F%2Fclassiccycles.org%2Fmedia%2F%2FDIR_1653304%2FDIR_1653404%2FDIR_1656704%2F89c4402e515d5252ffff82503f6906d9.pdf&clen=413996&chunk=true
« Last Edit: January 01, 2022, 05:50:30 PM by McCabe-Thiele (Ted) »
Offline Kelly E
  • Geriatric Hooligan
« Reply #7 on: January 01, 2022, 09:46:50 PM »
You are supposed to pull out the pin so Dyna's piece seats all the way down.
The Rust Brothers Garage Collection
1974 Honda CB550 K0
1975 Honda CB400F Super Sport
1979 Honda CB750F Super Sport
1980 Suzuki GS1100E
1982 Honda CB900F Super Sport
1983 Honda CB1100F
1984 Honda VF700S Sabre
1984 Honda VF1000F Interceptor
1990 Moto Guzzi 1000 Le Mans
1994 Kawasaki Concours ZG1000
2006 Harley Davidson Fat Boy
« Reply #8 on: January 02, 2022, 11:42:36 AM »
Thanks very much guys! Ted that’s a comprehensive library of info found there. Jesus the more I find out it really is a miracle that this bike actually ran at all.
« Reply #9 on: January 02, 2022, 12:07:14 PM »
Thanks found it via a link on a google search that took me back to the sohc site here to a post from 2016 - the Honda wiring colours list is usefull.
« Reply #10 on: January 02, 2022, 03:24:14 PM »
I thought the same when I started to work on Chewy, I'm surprised anything happened at all when I pressed the button for the first time!
