Author Topic: Petition  (Read 15095 times)
Offline allankelly1
Petition
« on: December 21, 2021, 11:36:11 PM »
If a Uk biker feel free to share and sign as this will affect us all at some point
Happy Xmas Al
https://petition.parliament.uk/petitions/600954
Re: Petition
« Reply #1 on: December 22, 2021, 12:09:17 AM »
This legislation seems like a sledgehamer to crack a nut especially when you look at the causes of one of the biggest breaches on emissions - so called Dieselgate where manufacturers & designers cheated.
It's interesting as my Jeep WK1 is currently in limp mode due to the swirl motors showing a fault last week - it's an old motor 2005 so not worth a deal even though it's only done 85k miles.
New swirl motor actuator in the Mercedes designed  OM643 engine with labour plus potential replacement of the intake manifolds is a £600-£1500 to fix - a work around that disables the swirl motor circuit costs around £200 fitted. The modification does not affect the emisions - small loss of power - around 8 bhp not a big deal for a V6 3 litre.
This legislation could make my intended repair illegal even though I still have a particulate filter & EGR valve in place.
Update:- Signed
« Last Edit: December 23, 2021, 12:57:56 PM by McCabe-Thiele (Ted) »
Re: Petition
« Reply #2 on: December 22, 2021, 07:59:40 AM »
Signed and it has over 100k signatures now. DoT has been very quiet in publishing this, and claim it is just to fill in some 'gaps' in legislation, whatever they are. Supposedly related to emissions but it it has the potential to stop customisation and to be used to stop customisation. ... we'll end up like Germany and others where everything has to be type-approved.
Re: Petition
« Reply #3 on: December 22, 2021, 10:36:18 AM »
Signed
Online Oddjob
Re: Petition
« Reply #4 on: December 22, 2021, 02:21:37 PM »
Also signed.
Re: Petition
« Reply #5 on: December 22, 2021, 03:12:50 PM »
I signed it as well. However, the reporting of this issue has been very poor as per the usual UK media. The actual intentions of this bill are not as reported which is nothing more than hysterical scaremongering. I signed it though as can you trust any government to do as it says.
Offline allankelly1
Re: Petition
« Reply #6 on: December 22, 2021, 03:27:12 PM »
Yes good point about the government
Cannot even follow its own rules it made last Xmas
Re: Petition
« Reply #7 on: December 22, 2021, 03:52:07 PM »
Signed.
I also responded via the original consultation paper a couple of months ago after Stuart Fillingham posted the story on his YouTube video.
Re: Petition
« Reply #8 on: December 22, 2021, 04:29:15 PM »
Signed too.
Re: Petition
« Reply #9 on: December 22, 2021, 04:47:02 PM »
Signed, though all this does is permit a ‘debate’, which never goes well if history is anything to go by.
Offline MCTID
Re: Petition
« Reply #10 on: December 22, 2021, 04:59:56 PM »
I remember having a conversation about this 'issue' before June 2016 with my Son in Law who owns a Garage employing about 20 peeps in Manchester. He specialises in German Cars and his 'claim to fame' is his hourly rate which is a fraction of the relevant Main Dealer prices.....he also gets a lot of Kudos because he only fits OEM parts and all his Technicians are Factory Trained, the Manufacturers warranty is valid. He also knocks 10% off the price of OEM parts and he will also tell you if a VW badged part will fit your Audi or Porsche and the price difference.....i.e. a Brake Caliper in a VW box will cost 1/3 of the same part in a Porsche box. It's the same part but if your car is out of Warranty, do you really need to spend a lot more dosh than you need to.....or Porsche want you to ?
His business also handles a lot of Fleet Cars and Vans, and again, he will offer Owners an alternative part if there is a significant saving as many parts for Citroens, Renaults, Peugeots and Vauxhalls are basically the same, but the price difference may be significant. Another factor is who can supply the part today or will you have to wait 48 hours for it to be delivered from the Main Dealer/ Motor Factor - a vital factor when you have a vehicle stripped down on the ramp taking up workshop space awaiting parts to get it back on the road....think Fleet Vehicles here folks !
He tells me that other Independent Garages like his will also offer alternative parts just like he does, and for a large Fleet, the annual savings can be substantial. Fleet Owners expect him to be proactive and to add value wherever possible and repeat business is often won by passing on these savings.
The conversation we had back in June 2016 was about an EU initiative to prevent the use of non OEM parts on vehicles....which would have had a major impact upon his business without adding any real benefit or ensuring Customers had a choice. Although we all accept that Emissions should be tightly controlled, is it really a good thing that a mild steel exhaust system provided (not made by the Vehicle Manufacturer but outsourced) retailing at £250 might be outlawed and instead the Customer has no choice but to buy the Manufacturers Stamped exhaust system at £750 ! It's made from the same material, made to the same specifications and made by the same Factory, but you will only be able to buy it from the Manufacturer and you will have to pay the asking price they want ! So much for choice, value and the 'free market' ! Similarly, should a Headlight or a Door Mirror which you can buy as a Pattern part be available for £100 or £50 or should you be forced to pay 4 or 5 times that price because legally, you can only buy it from the Main Dealer ?
Back in 2026, my SIL was aghast that such an initiative was being considered and felt it was a negative proposal........and although many thought it had bit the dust since then, it's obvious that somebody somewhere has refused to let it drop and is trying to introduce it again !
I signed this petition and also responded to the call for comments that the BMF asked for - despite it being a PITA to complete and return the formal Response Form......in my experience, when any Civil Service Department deliberately makes it difficult to air your views, then there's usually a very 'dodgy' reason behind their subterfuge and sleight of hand........i.e. they don't actually want people to comment because they have no interest in what Joe Public wants as they have already made their minds up.
Let's hope that common sense prevails in this matter, but if it doesn't then we may all need to badger our local MP's or we will once again be stuck with it !
Offline Moorey
Re: Petition
« Reply #11 on: December 22, 2021, 06:20:55 PM »
  Signed but a waste of time as nothing has ever come of any of these petitions All 100,000 sigs does is mean it will be considered
  for debate not debated.
Offline allankelly1
Petition
« Reply #12 on: December 22, 2021, 07:13:52 PM »
When you think about it, if it’s just to do mainly with emissions, I see it as back door tactics by the government to force use over to electric as cost of OEM parts for a 5year old ICE vehicle will be stupid
« Last Edit: December 23, 2021, 12:55:43 PM by allankelly1 »
Offline Athame57
Re: Petition
« Reply #13 on: December 23, 2021, 02:32:07 AM »
Signed.
1978 CB400F2 named Elen.
Re: Petition
« Reply #14 on: December 23, 2021, 02:04:19 PM »
Reading MCTID's post does make one ponder why the government came up with the idea that it was legislation that was remotely a priority - I suspect the hidden power of money & vested interests at work with some clever lobbying.
We haven't changed the legislation that covers most assaults since 1861 (Ye Olde "Offences Against the Persons Act 1861") so why even consider it - the usual route is a Statutory Instrument to add the offence to existing Construction & Use Regulations without the need of new legislation !
« Last Edit: December 23, 2021, 02:07:21 PM by McCabe-Thiele (Ted) »
