Author Topic: Fuel Hose Retainer  (Read 4836 times)
Offline Dave
Fuel Hose Retainer
« on: January 01, 2022, 11:08:57 AM »
I've just received a new fuel hose from David Silvers. OD is 10mm (ID 5.5mm). Problem is, it won't pass through the retaining clip mounted on the carb, shown here:
I tried using a small section of hose to test and it is so tight it severely constricts the ID of the hose. It seems to me the clip would be happier with something smaller (8-9mm OD maybe?)
Anyway - can someone provide a link for a suitable fuel line that will happily work with the 400F.
Dave
Re: Fuel Hose Retainer
« Reply #1 on: January 01, 2022, 11:27:08 AM »
You could open up the clip just enough to hold the fuel hose. 🙂
Offline Dave
« Reply #2 on: January 01, 2022, 11:36:49 AM »
The clip loops completely around the hose. In short, no - that won't work...
« Reply #3 on: January 01, 2022, 11:42:28 AM »
Think he meant using  a drill to open it up?
Offline Dave
« Reply #4 on: January 01, 2022, 11:48:49 AM »
OK, I see what you mean.
However, I would rather just get a hose that fits, if at all possible.
Offline Deano400
« Reply #6 on: January 01, 2022, 12:53:03 PM »
I use this - recommended by other members from memory
https://www.ebay.co.uk/itm/140696477056?var=440044655770
Its the 9.4mm ID (standard hose is 5.5mm from memory)
« Last Edit: January 01, 2022, 12:55:02 PM by philward »
Offline Dave
« Reply #7 on: January 01, 2022, 01:02:28 PM »
Thanks guys for the links - perfect...
« Reply #8 on: January 01, 2022, 01:33:04 PM »
Er, no. 😂 I thought it was one of the open ended clips that can be bent to size.
Offline Dave
« Reply #9 on: January 01, 2022, 01:35:00 PM »
Yes Gareth, that would have been so much easier  :)
« Reply #10 on: January 01, 2022, 02:35:23 PM »
Indeed…looks,like,some new hose.
