Author Topic: how to clean valves properly  (Read 10159 times)
Re: how to clean valves properly
« Reply #15 on: January 10, 2022, 10:47:58 AM »
Hope someone can teach me on this. Is it true that some valves are special and are not supposed to be lapped and if you do, you will do more harm than good? Second question: what is it precisely, that causes valves to wear?
These old bikes mostly use steel valves which need lapping in to get a good seal. Race bikes and some modern high performance bikes use exotic, lightweight materials which might need special treatment.  That's beyond my 'need to know' knowledge.
Valves wear because they are opening and shutting thousands of times a minute. The valve seat is getting hammered by the closing valve every time. Any wear in the valve guide means the head of the valve can move sideways a little and then the valve doesn't seat exactly on the seat and that causes more wear. HTH
« Reply #16 on: January 10, 2022, 11:08:10 AM »
There is a tool for lapping valves. Fits in a battery drill and it oscillates the valve. Saves loads of time and sore palms.
Had mine for about 35 years and still going strong. They have something similar on Amazon for about 20 quid
I had one of those tools for many years but eventually the plastic casing cracked so I had to bin it - it worked okay but I still found the achiles heel was the same as using a manual stick - the cup comes off the valve.
https://www.ebay.co.uk/itm/402108621845?epid=27017016881&_trkparms=ispr%3D1&hash=item5d9f8aa415:g:IPwAAOSw5BVeW9bP&amdata=enc%3AAQAGAAACoPYe5NmHp%252B2JMhMi7yxGiTJkPrKr5t53CooMSQt2orsS%252BMKizvpuEDUfX4dvRWfUzURblK36%252BPNf4lX6vgxusHh0GHwCj0dJ%252BH1Ebar3rSvQXHHlOooirdet7SZ5H7h0OGGiMHgxuLEBJ8KzWOj8GsVY%252FlgrqLPYc3v9SwUudsvKNrDj8vGl%252FEX1wrFPODxM2zJIZCcETQ7%252BmT9bKdqNVfh%252B0xuIINfIAJRsRlQOwMZAIZM8ZFSw3E30HZNGueMJOBBaKvX50Xo%252BT%252BS7D%252FNh%252FM2Di1NecTc8Ge0hyJh7yjLplGvkc%252Fzy%252FbD0cdEQsKShM1%252BuWg0w%252F99ycu3fZ6lg4Xo5JJ%252BdriAYUeNCUoJVCI3vaOPpIgclSVGLuUv%252BVfYoVX98U7HugW%252FNe8zcB0xMHe3tOZ5Y97Xg%252Bzq06ezth3BK1mBCgWfpPf%252B%252BdZDGFzy4tPu%252B1gWPZGRxDChw5HDiTia4lSUUA%252BQlTBU2%252BHS61FB82rk3yNlMwFe2cpYAUQS2lr9A7LnK1blM9ZSXNph3zcZNrhhF8anuU0zc2y8KCd%252BVWYK4NE2Wzi%252FEgqgjYkb6ZQVx1o%252BQ5RkLyuvxyMsFMHMY7zg%252Bmb2zCBAZz0epUSD5emDdHvHjus97O%252F1yeI2GjhzH0hs5OXz63I7nM9rPsWAcS5kyucZcR8JNT8FZ81Wp9CwoKmKUjF%252F9pZnU982QaXZZ3jlT982pGi2a%252FYNDYT6jIZj3BWzdnAXmVl%252BJHg%252Fzw2ozkOgPnXyy7UtAL7qod8IkhN2PSA%252BLAaMuf0uG6NEbf4eGCEsVYopWPkWx2TU1Td%252FVa3kHVjUtnOllTv5ILwsuaw4JfuyGcLe%252FpwdoeKB8spvkhcwwR6FklmJREj3%252FBLnP7WxuMOvgEncrQeMsTw%253D%253D%7Cclp%3A2334524%7Ctkp%3ABFBMopbFushf
Offline heli_madken
« Reply #17 on: January 10, 2022, 05:20:40 PM »
My tip to stop the cup coming off the valve - find the stickest chewing gum you can!!
« Reply #18 on: January 10, 2022, 07:03:25 PM »
The easiest and to me, the best way to lap a valve is to use a tap wrench, the chuck type. Fit the valve with paste attached and grab the exposed stem with the chuck. You can then pull against the valve whilst oscillating the valve at the same time, far better than spinning the valve. You can vary the amount of pressure depending on how bad the surface is. You can check the condition of the face by lowering the valve as far as the chuck allows and inspecting the face. One of the better things about this method is that when you think you have a seal leave the chuck attached, fill the port with petrol whilst pulling on the valve, if it leaks past the valve head you can easily spot it, if it doesn't you have a decent seal without having to fit the springs etc. Of course you check the seal when the springs are attached using the same petrol method. Even a very small leakage can be seen by the petrol just misting through.
I had to do 24 valves on a CBX head one time and this method was the one I used. The sucker method is exactly that, for suckers. Believe me, this method really works.
Example of a chuck type tap wrench, make sure the jaws are big enough to take the stem diameter but at the same time make sure the chuck with fit down the valve spring hole.
https://www.ebay.co.uk/itm/393855967252?hash=item5bb3a52014:g:RYoAAOSwQeNh2Y1d
The very best tap wrench is the Snap On as it has a spanner fitment, saves you trying to grip the wrench with your fingers to get it tight enough.
https://buy.wesco.com/Tools-and-Installation/Drilling-Tapping-and-Milling-Tools/Tapping-Tools/Tap-Wrenches/SNAP-ON-TOOLS/Tap-Wrench-1-4-1-2-in-Tap-High-Carbon-Steel/TD50/p/78582828061-1
You could buy a normal one like the first link and grind some flats onto the chuck I suppose.
Offline kevski
« Reply #19 on: January 10, 2022, 08:24:04 PM »
Additional question to this, what would make the valves special (do I have them?  ::) )
Generally nothing as long as the seating area is in spec, seats can be two or three angle.
Offline RBoss
  • CB500 Four K0 1975
« Reply #20 on: January 13, 2022, 01:00:07 PM »
So I have been busy with the sucker method... And I agree Oddjob, its pretty frustrating when the suction cup starts getting loose all the time, I will switch to the tap wrench soon, if I am not there yet.
However I am getting pretty good results already and I am just wondering what you all would do. Here's the situation:
I have been lapping with coarse compound and was able to get the biggest pock marks off the valves. The pock marks that I am having trouble with getting of are these ones (in the picture).
Would you either:
1. go on lapping until these pock marks get off and the surface is smooth (I don't know how long that will take) and what the maximum is one should keep lapping valves.
2. do a test with water or gasoline in the valve area and see if it leaks--> when it doesn't leak, leave it like this
3. leave it like this --> it doesn't make that much of a difference
4. buy a new replacement valve as this has relative impact on engine performance
I'm wondering what you guys would do!
CB500 Four K0 1975
Amsterdam - Netherlands
« Reply #21 on: January 13, 2022, 01:42:46 PM »
Do the petrol test. See how that goes.
I'd keep on lapping for a while yet but that's just me.
« Reply #22 on: January 13, 2022, 01:44:28 PM »
If you have that much pitting on the valve faces, the valve seats will also be pitted If you keep grinding you run the risk of stepping the valve face. This thread explains what needs doing.  http://www.sohc.co.uk/index.php/topic,20419.150.html
Offline RBoss
« Reply #23 on: January 13, 2022, 02:12:14 PM »
That looks like a top end quality rebuild! :o
I'm trying to avoid cutting corners on my rebuild, but I believe I am not at that point yet.
I think the valve seats look pretty good. (apologies for the poor photo quality)
[ Guests cannot view attachments ] [ Guests cannot view attachments ] [ Guests cannot view attachments ] [ Guests cannot view attachments ]
I'll start with the petrol test and probably go on lapping for a bit.
Thanks for the advice!
CB500 Four K0 1975
« Reply #24 on: January 13, 2022, 02:38:46 PM »
No 1 looks the worst. Even that ain't too bad.
