Author Topic: Electronic ignition  (Read 95866 times)
Re: Electronic ignition
« Reply #165 on: January 22, 2022, 03:45:07 PM »
   Hi Ash,
  I had my original BB black box develope a fault after about 20yrs ,
 it failed to switch on occasionall,,you could just hear a "click" when it switched on,.
  but sometimes it didn't.
  know idea if there is a relay inside,
  I now have the red box,with  BB coils and works perfectly.
« Reply #166 on: January 22, 2022, 07:10:20 PM »
   Hi Ash,
Do you still have the old one John?
Offline oldboy
« Reply #167 on: January 23, 2022, 10:41:25 AM »
Moderator: I promise I will never again ask a "fors and against" question that could take up so much forum time!!!!!!!!!!!!!!!!!!!!! But the knowledge out there is endless.  Thanks fella's
« Reply #168 on: January 23, 2022, 10:54:46 AM »
   Hi Ash,
Yes,!!!
PM me,
I will send it for you to explore
Offline allankelly1
« Reply #169 on: January 23, 2022, 11:08:23 AM »
   Hi Ash,
Hi John
Yes I have a full BB system and there must be a switch or relay as instructions say that after 15sec of engine stop if the ignition is left on the system automatically switches itself off I guess via this relay
Best regards Al
« Reply #170 on: January 26, 2022, 10:42:54 AM »
I’ve just seen a squirrel…..
Seriously though. I transistorised switch has got to be a better solution to achieve a superior Ldi/dt HT performance and reducing stored energy across the points Cdv/dt?
I’m betting that if CDI or and EI was available to Mr Honda back in the 70s he would have used it in preference to a mechanical system.
Just wondering….
Interesting point, there's more to the fundamental part and characteristics of this ignition type than first appearance.
Undoubtedly Honda would have known then the variance in options available to them, with some more suitable than others. The general view given out over many years by popular opinions that the bigger the spark the better. In essence, that the flash-bang-wallop and lightning-level-blow-your-trousers-off provision of sparks is going to out perform anything else couldn't be more inaccurate.
CDI for example could be viewed as mostly unsuitable for these four stroke combustion designs from this time. Two stroke, yes, as they have a fundamentally different requirement in their combustion chamber. More related to diesels in reality, the central (usually) mounted plug with almost perfectly sized initial burn chamber in a cone geometry, is perfect for high energy short spark duration output of CDI systems.  It gets the mixture going locally to the plug which effectively ignites the rest of the chamber as it comes up to squish (and why tuners often concentrate on their favourite swish geometry) to efficiently light the remaining charge as it comes to full compression.
The honda four stroke strategy is completely different (as are most compared to 2T ) in that the spark duration is lengthened to work with the engine to burn effectively. Of the ignition system modifers/suppliers only Hondaman talks about this element, and mimics the Honda stategy in switch time to deploy the coil output in extending the spark.
In essence, the Honda design (I'd consider them absolute masters of this capability) get the complete four stroke cycle to optimum such that it's easy to ignite the chamber,  it really doesn't need anything with increased energy to fit the strategy they've created.  You can throw as much flash-bang at it as you wish, it won't make a blind bit of difference (compared to properly performing original) as you aren't changing combustion conditions by doing so.
In reality, if you shorten the spark too far the risk of uncontrolled detonation travels closer to the ideal combustion, eating safety margin as it does so.
The only thing supplimentary systems do is to take switch load from breakers and make them last longer.
« Reply #171 on: January 26, 2022, 11:05:18 AM »
Mr Honda did use CDi extensively in the very late 70's into the 80's and beyond on both the CX500, Superdream , CBX etc. made by Hitachi and it wasn't multi-spark AFAIK.
Back in your naughty corner Ash  :-X :-X
« Reply #172 on: January 26, 2022, 11:15:06 AM »
Oh, definitely but a fundamental change in combustion chamber as the four valve at narrow angle design moves in geometry toward that discussed in the 2T part. And one of the reasons for designing in that way.
You'll see a much reduced overall combustion time for that type of head which is why high revving faster engines use the layout as it has a much higher ceiling in combustion terms.
You can broadly separate them by looking at total ignition advance.  The lower that is the faster the chamber is burning, and by default doesn't need the same lead time from ignition to get the burn coinciding with the piston being just past TDC.
« Reply #173 on: January 26, 2022, 11:35:24 AM »
Here's the "missing link" Ash with CDI type
The Honda RCB endurance racer of 1970s. The bottom end is straight 750 SOHC, note ignition removed,  twin cam 4 valve head, ignition I think is picture central (see the two opposed pickup) running on the rear of alternator spindle that's geared/chain driven to left of crankshaft.
They also went further on later modification of this engine by converting it to gear primary drive.
« Reply #174 on: January 26, 2022, 12:09:13 PM »
AFIK, we have not seen verifiable signs of a created longer burn time by adding resistance, let alone that we have seen testimonies about a benificial effect, with the exception maybe of one by a gentleman on an elevated mountain road in Colorado.
Could it happen? In theory yes. After all, I vaguely remember something about Rc time from school. It's my view, it will be hard to tell, if there's a significant and benificial effect. The first can be realised by applying test equipment I cannot afford. The latter will be harder to tell. How can you tell what the burn time attributed over the flame front's performance? With a stock ignition or with a transistorized one there will be ample burn time during enough degrees crank rotation. With discharging capacitors this might be different however. As I understand it, there's no reserve and a CDI may not be able to 'try again' like the pic below shows.
« Last Edit: January 26, 2022, 12:12:13 PM by deltarider »
« Reply #175 on: January 26, 2022, 01:33:59 PM »
He doesn't seem to be saying anything within this element (output form) that's not known about in points+condenser type ignition.
But also not discarding it in his translation to solid state switching.
The "spark form" is simply a characteristic of switching operation for condenser assisted switching, certainly it can be looked at as imperfection, but with the overiding caveat that the original combustion design, strategy and R&D was completed within that status. It therefore forms part of the whole system performance as designed. To delete it with "improved" switching has implications that are unquantified and will likely have an impact on combustion.
« Reply #176 on: January 26, 2022, 01:41:53 PM »
Isn't understanding exactly what Honda designed and researched then a fundamental part of bringing a modification to their system?
Certainly it's possible, but are you just going to "luck" into it or appreciate why you are changing something and what the effects really impact.
Offline allankelly1
Electronic ignition
« Reply #177 on: January 26, 2022, 01:47:25 PM »
Just a question but original combustion chamber design ignition curve would have been based on leaded four star fuel. So would modern fuels affect combustion, speed heat of combustion etc as on another forum it was mentioned that adding ethanol produces a smaller bang and affects detonation (reduces it)
Or maybe I am talking rubbish and happy to be corrected
Best regards Al
« Reply #178 on: January 26, 2022, 01:56:44 PM »
Ultimately developed as a 2star runner (if that's the right way to describe it) and with zero lead ability from the off. Whether it was for unleaded or because a aluminium casting with valve seat inserts naturally evolved in material specification to cope with that, I'm unsure.
Relatively low compression ratio gives it a large, and natural, fuel quality acceptance without any significant adjustment.
Many of the characteristic of these engines are now seen in current designs, they really were very far ahead in the experience and knowledge they brought to this subject.
Using a high octane fuel in them has all but zero observable effect.
Offline allankelly1
« Reply #179 on: January 26, 2022, 01:58:20 PM »
Thanks K2-K6
Every day is a school day
Best regards Al
