Author Topic: screw setting  (Read 5298 times)
Offline captaindonutbikes
screw setting
« on: April 11, 2010, 03:13:08 AM »
so what should this be set at for start for fiddling or should it be all the way in? mixture is set at one a half turns out carbs have bench synced for now.
cb550k3 running pod filters pd46c carbs. Marvin 4 into 1 race exhaust.
thanks
cb550k3 cafe
Re: screw setting
« Reply #1 on: April 11, 2010, 10:02:58 AM »
That screw is the one for the vacuum adaptors
Re: screw setting
« Reply #2 on: April 11, 2010, 12:16:16 PM »
super, cheers Brian
cb550k3 cafe
Offline Yoshi823
  • Biker to the bone...
Re: screw setting
« Reply #3 on: April 11, 2010, 11:23:04 PM »
If you havn't already found them the mixture screws are located at the front of the carbs just in front of the float bowl. For the K3 they should be about 1.5 turns out.
 I hope that you havn't lost the very small 'o' ring that goes above the very small washer that sits on top of the spring that goes onto the mixture screw...
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
Re: screw setting
« Reply #4 on: May 13, 2010, 06:22:18 PM »
these carbs have been completely rebuilt with new o rings needles floats etc. i made sure i read a whole heap of builds on the .net site before hand but thanks for the concern.
cb550k3 cafe
