Author Topic: Oil filter housing bolt.  (Read 4951 times)
Offline Bradders
« on: January 28, 2022, 03:23:35 PM »
Afternoon all. Have had a nightmare of a time getting the oil filter housing bolt undone. ( it’s only been on for a year). With regard to fitting the new one on any tips for avoiding the same difficulty in a years time?  Regards, Chris.
Re: Oil filter housing bolt.
« Reply #1 on: January 28, 2022, 04:08:00 PM »
Grease/oil the O ring by the head,
Like tappet covers,they don't need to be to tight
« Reply #2 on: January 28, 2022, 04:32:05 PM »
On the 750k3, it came with a 1” head on the filter bolt. That’s the biggest I’ve seen. Scarey prospect the damage that could do with some muppet on the other end of the spanner. Thankfully the threads in the crankcase were fine.
Offline Bradders
« Reply #3 on: January 28, 2022, 04:43:39 PM »
Do you think it’s ok to torque it up to the level the manual says, or is that too tight?
« Reply #4 on: January 28, 2022, 04:51:35 PM »
Never ever used a torque wrench, just nippedtight
Offline Bradders
« Reply #5 on: January 28, 2022, 05:58:37 PM »
Thanks Bryanj. I shall do the same then, maybe it won’t need a blowtorch to get it off next time then.
Offline 400 Cafe Racer
« Reply #6 on: January 28, 2022, 09:43:19 PM »
Also - think canister filters doing the same job - only hand tight with no tools, as Bryan says, just nipped tight is all it takes if the "O" rings are all good.
Retired Automotive Engineer   MIMI, MITRE, DMS, MCMI.
Latest     - 1989 CBR600F1 (FK) PC23
              - 1979 CB400/4  Cafe Racer - Parakeet Yellow
              - 1939 Velocette GTP 250 twin port Two stroke
1988-91 - Lamborghini Countach QV replica design and
                 build - 3000hr spare time project -Now Sold
In 1956 at 12yrs old and dirt tracking
              - 1937 Rudge 500 4 valve
              - 1940s Royal Enfield 225sv
              -  Ex WD Norton 500sv
Offline Bradders
« Reply #7 on: January 28, 2022, 10:27:18 PM »
Thank you all for your replies. I think it must of got done up too tight last time as it was a sod to get off.
« Reply #8 on: January 28, 2022, 10:36:56 PM »
One reaso why Honda had a piddly 12mm hex on the bolt
Offline Seabeowner
« Reply #9 on: January 29, 2022, 10:23:43 AM »
And never use a 12pt ring spanner on the 12mm head. Six sided socket only.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
