Author Topic: Whats the thinking - front brake switch replacement.  (Read 4573 times)
« on: January 29, 2022, 12:44:05 PM »
Before I try to bleed the front brakes I wondered if I ought to replace the front switch as a matter of course / safety as its over 40 years old.
DS have a replacement at £18.50 Plus P&P - are there branded aftermarket options that are suitable?
Guidance as to sources available welcome.
Re: Whats the thinking - front brake switch replacement.
« Reply #1 on: January 29, 2022, 01:14:00 PM »
Is it leaking?
Does it work?
I suggest you keep it until it doesn't
« Reply #2 on: January 29, 2022, 01:39:23 PM »
Don't waste yer brass Ted, I'm with John.
« Reply #3 on: January 29, 2022, 02:47:30 PM »
I’m quite sure mine is the original one on the 750 complete with yellow paint mark. Left as is, nearly fifty years old works a treat.,
« Reply #4 on: January 29, 2022, 03:26:51 PM »
Same with mine, leave it be
« Reply #5 on: January 29, 2022, 05:52:55 PM »
I guess they are more reliable than oil switches I'll leave it as it is unless I find it leaks.
« Reply #6 on: January 29, 2022, 06:06:12 PM »
I bled mine with the syringe method through the bleed valve on Caliper with almost instant success, my system was completely dry with all new pipe work, also used Dot5 fluid which doesn’t harm paintwork.
« Reply #7 on: January 31, 2022, 11:52:04 PM »
Was that filling the system with fluid pushed up via the bleed nipple or using it to pull fluid down by means of a partial vacuum?
« Last Edit: February 01, 2022, 01:11:51 PM by McCabe-Thiele (Ted) »
« Reply #8 on: February 01, 2022, 08:42:41 AM »
Pushing up through bleed nipple Ted. Just filled syringe and gently pressured up.
« Reply #9 on: February 07, 2022, 01:02:56 PM »
As it had warmed up a bit I decided to get some fluid into the front brakes - the brakes had no fluid in them so a clean start. I have gone for Silicone fluid. I put 150 cc in my syringe then fed the fluid through the caliper bleed nipple - nice and steady until it appeared in the brake reservoir base - tightened the nipple then topped up the reservoir - about three pulls of the brake lever - a few air bubbles emerged then a good reasonably solid lever.
Emptied the unused fluid back into the bottle - thanks for the tip Roo a great method with no waste.
« Reply #10 on: February 07, 2022, 05:57:42 PM »
Thanks ;)
It was Johnny! ;D ;D ;D
« Reply #11 on: February 07, 2022, 06:04:41 PM »
Thanks ;)
My Bad - thanks Johnny.
