Author Topic: Brake pads  (Read 2570 times)
Offline AndyD
Brake pads
« on: February 02, 2022, 07:29:40 PM »
Hi,
Just looking to order brake pads and wondered what opinions are on varying types available.
I've seen organic, semi-sintered and ceramic available and no idea what pros and cons are.
Are any better / worse for squealing which seems a big issue with these brakes?
Cheers,
Andy
Re: Brake pads
« Reply #1 on: February 02, 2022, 08:49:19 PM »
Tbh a lot depends on what aspects are important to you. I personally have always liked softer pads others want hot performance braking so a hard pad for them. The softer the pad the better the initial cold braking. Many here like ceramic  as they don't fade easily I am led to believe. Like tyre options it's personal choice.
Secondary considerations might be disc wear, soft pads are great for keeping the disc clean with good wear properties - since the abolition of Asbestos some wear is inevitable whatever you go for - its a trade off imho. Not forgetting brake squeeling as a side show.
« Last Edit: February 02, 2022, 10:09:40 PM by McCabe-Thiele (Ted) »
Re: Brake pads
« Reply #2 on: February 03, 2022, 09:32:19 AM »
I use Vesrah,
Quite a soft pad,brakes ok,
But a bit iffy in the very wet,
EBC fibre, I could never get to work in the dry,but after a rainstorm they worked great for a short time,
Ebc semi sintered, great when used hard,not much cold bite,
Reasonable in the wet,prone to wear the discs,risk of squeal.
I am considering a mix and match,
Vesrah one side of the caliper, and  EBC the other.
Bare in mind, the technology is 50years old,although I would hope  the pad materials might be more up to date.
Offline AndyD
Re: Brake pads
« Reply #3 on: February 03, 2022, 12:17:47 PM »
Thanks guys,
I'll have a Google around and see what looks suitable.
Cheers,
Andy
