Author Topic: How to remove rocker arms?  (Read 3075 times)
Offline alexdecker
« on: February 19, 2022, 02:41:12 PM »
Hey all
Got the new cover, with the 4 extra screws holding the rocker arms in place. Have unscrewed the bolts, and tried tapping down on the uncovered screws. They are not budging, like not even a little, which makes me think I might be doing it wrong? Can anyone advice in which direction to tap, to loosen the rocker arms?
Re: How to remove rocker arms?
« Reply #1 on: February 19, 2022, 02:46:52 PM »
They get incredibly tight and you hit on the thread end
Offline alexdecker
« Reply #2 on: February 19, 2022, 03:05:43 PM »
So basically hit them from the top and directly down, and just really hard and a lot?
« Reply #3 on: February 19, 2022, 03:11:02 PM »
But put the nut back on at least 3/4 before you hit it. Apply a little heat to. It worked for me. Make sure the cam cover is evenly supported too. But I’m sure you are on to all this.
« Reply #4 on: February 19, 2022, 07:49:27 PM »
I used a large pin punch so the hammer hit that and not the pin directly. A bit of heat never goes amiss either.
A nut put onto the threads is a good idea as stated, that way if you accidentally damage the thread the nut coming off can straighten them again.
Offline alexdecker
« Reply #5 on: February 20, 2022, 01:25:52 PM »
Did the nut on, and a lot of heat. But damn. Really had to go to town with a hammer on those. One of the screws even bended a bit. But they got off!
My god, these old machines. Literally everything is stuck on them.
