Other Stuff
Misc / Open
Unidentified part.
Topic: Unidentified part. (Read 2811 times)
Johnny4428
Unidentified part.
February 20, 2022, 06:33:51 PM »
I would be some chuffed if somebody could identify this part. I had stripped a clutch from a C90 and was cleaning all parts in a tray with a mixture of diesel and petrol, and when it came to emptying out the tray in among the waste oil this clonked out of the bottom of the tray. I’m quite certain it’s not part of the clutch having checked the parts list. So can anybody identify the part. It is a mystery.
Oddjob
Re: Unidentified part.
February 20, 2022, 06:49:31 PM »
It looks like a thrust washer and isn't there one first onto the clutch shaft before the outer basket.
Does it have a slight chamfer? might be the B lock washer which sits behind the castellated nut.
Last Edit: February 20, 2022, 06:55:41 PM by Oddjob
Johnny4428
February 20, 2022, 07:10:00 PM »
Here’s a picture of the other side and parts diagram.
Oddjob
February 20, 2022, 07:22:14 PM »
Yeah that looks like the B lock washer, as you wind down the castellated nut that will flatten out and it trying to reform it's shape acts like a spring washer.
Parts book I looked at was different, what year and model is the C90.
good friend poems
Last Edit: February 20, 2022, 07:26:37 PM by Oddjob
Johnny4428
February 20, 2022, 09:32:33 PM »
It’s a 1981 C90ZZ Ken. It’s too big to fit in the clutch recess to come anywhere near the nut and lock washer.
Last Edit: February 20, 2022, 09:35:31 PM by Johnny4428
February 21, 2022, 12:11:55 AM »
Have you done a filter change on a four usng the same drain tin, itlooks a bit like the washer between filter and spring, or part number 24 on the pic above
Last Edit: February 21, 2022, 12:14:42 AM by Bryanj
Johnny4428
February 21, 2022, 11:57:12 AM »
Good call Bryan! But a good bit bigger than oil filter spring seating ring.
February 21, 2022, 02:33:53 PM »
Cant gauge size from solo pic so no idea mate
Oddjob
February 21, 2022, 03:28:31 PM »
Any chance it was left in the tray from a previous bike?
Can't spot anything like it on the C90ZZ parts book.
Johnny4428
February 21, 2022, 04:58:47 PM »
The tray had been clean prior to putting fresh cleaning liquid in it. There is a chance that it was sitting in the waste drum filler from a previous job, but I could have sworn there was a clonk when I emptied it out. I am quite satisfied that it was not part of the clutch I am working on. Waiting on new springs and gaskets, will put together then and make sure there are no rattles and the clutch functions as it should. But it will have to remain a mystery for now.
Reply #10 on:
February 21, 2022, 05:52:07 PM »
has it a kickstart shaft, sometimes a washer there before case goes on
Lobo
Lobo
Lobo
Reply #11 on:
February 21, 2022, 09:24:50 PM »
… at 40mm internal dia (suggested in your 1st pic), it’s surely not part of any C90 😂
ST1100
Reply #12 on:
February 22, 2022, 02:03:01 PM »
Looks like one of those washers sitting between fork-spring and spacer... any such work done recently?
STOC #637
Other Stuff
Misc / Open
Unidentified part.
