Author Topic: Engine bolt sets in EU?  (Read 3431 times)
Offline alexdecker
« on: February 23, 2022, 04:29:59 PM »
Ebay seems flooded with bolt sets for the engine, the covers, carburettors etc. But they all ship from the US. Does anyone know of bolt sets sent from EU?
Alternatively, does anyone have a convenient complete list written out on all the bolt sizes for all the different sections?
- Alex
Offline RBoss
  • CB500 Four K0 1975
Re: Engine bolt sets in EU?
« Reply #1 on: February 23, 2022, 05:04:22 PM »
Hi Alex,
I have recently composed my own list of bolts for the outside covers, its attachted. There are links to the parts on CMSNL.com + amounts and sizes and lengths. Hereby I don't take responsibility in any mistakes or typo's in the list and some parts are in Dutch.
Hope its useful to you!
Ruben
CB500 Four K0 1975
Amsterdam - Netherlands
Offline alexdecker
« Reply #2 on: February 25, 2022, 11:37:30 AM »
Thank you - that is very helpful!
« Reply #3 on: February 25, 2022, 04:54:04 PM »
The problem with these sets Alex is that they normally use allen keyed socket bolts, this is not a good idea IMO, any that face upwards collect water in the recess, that promotes rust even in stainless steel sets, then when you got to remove them they round off leaving you with a problem of how to remove them especially if they are recessed in the engine.
A far better solution, again just my opinion, is to use what Honda did for the later engine, namely 8mm headed shouldered bolts.
The way Honda did their part number system makes it very easy to find the correct bolt. For instance, a 6mm x 28mm shouldered bolt with an 8mm head as used on say the 250N is part number 96000-06028-00. The important bit is the middle 5 numbers. 06 means 6mm, 028 is the length. So if you wanted say a 6x32mm long bolt you'd just search for 96000-06032-00. The last 2 digits seem to be the colour, in this case greyish like a normal bolt. There are some that are black for instance and those last 2 digits change to reflect that. Same with chrome type.
The best way to find these bolts if you don't want to buy new from Honda is to trawl Ebay and find a bike that's been broken, they quite often sell all the loose bolts etc in a job lot, if the bike is fairly new they are in really good condition so look like new anyway, any that aren't in the job lot can be sourced from Honda. Yes it can be more expensive but the results are far better.
Offline smoothoperator
« Reply #4 on: February 25, 2022, 06:54:34 PM »
That is an extremely useful tip, who would have thought these apparently random numbers could be so useful. If only Honda paint codes meant something.
Steve
2017 Triumph Bonneville T100
