Author Topic: Honda CB400 wiring connectors  (Read 5058 times)
« on: March 05, 2022, 02:01:27 PM »
Can anyone point me in the right direction please I need a couple of these I think they are 3.5 mm size 4 way connector?
I do not want to cut the ones off my old loom as it might be of use to someone else when I have a clear out.
.4 way connectors by Macabe Thiele, on Flickr
Re: Honda CB400 wiring connectors
« Reply #1 on: March 05, 2022, 03:03:55 PM »
Look up kojaycat i have found odd items there before and good to deal with, or at least were.
3.5 will take 3.9 bullets
« Reply #2 on: March 05, 2022, 03:24:00 PM »
If it's black wire Ted it should have a shroud to protect earthing as that's a power source.
« Reply #3 on: March 05, 2022, 03:52:27 PM »
Correct one of the reasons I replaced the loom as insulating tape was everywhere presumably because the sleeves had been removed for some reason. I've sourced some connectors from kojaycat a bit of a wait for delivery as they are closed for holidays.
Offline BigAl (Alan)
    • www.alans-electrics.co.uk
« Reply #4 on: March 06, 2022, 06:41:18 PM »
Not seen the 4-way 3.9mm socket connector on sale before, do you have the the product number/code? for kojaycat.
I have bought items from kojaycat before...good supplier.
Current bikes:-
Honda CB750 K4 (1974) USA
Honda XL500S (1980) UK
Honda CD175 sloper (1968) UK
Honda CB1100A (2013) UK
« Reply #5 on: March 06, 2022, 07:57:51 PM »
They only do the 3.5 mm one its TB-3.5mm-5W-1PC
Offline wildtapholer
« Reply #6 on: March 13, 2022, 04:22:32 PM »
I had the  same problem Ted, they are impossible to track down, I even tried a breakers yard to look at old looms but no body does them now they do multi block, I didn't want to use a block connecter on the 1 into 4 earth connecter so I had to solder 2 doubles together to ,get the same result/quote]
« Reply #8 on: March 15, 2022, 10:04:00 PM »
Offline Alexrayz
  • 1976 CB400F- Just making my way through the galaxy
« Reply #9 on: March 16, 2022, 12:19:03 PM »
They are japanese connectors, different from bullet connectors or fastons. In EU I usually find them on classic/ vintage automotive parts shops. Maybe you can find them in specialised electrical automotive shops?
If it aint broken don't fix it
