CB350/400
Cleaning crankcase mating surfaces
Topic: Cleaning crankcase mating surfaces (Read 2296 times)
billdn
SOHC Expert
never ever buy a basket case again!
March 19, 2022, 10:35:35 PM »
Any tips on removing old gasket cement from crankcase bodies before re assembly?
McCabe-Thiele (Ted)
Re: Cleaning crankcase mating surfaces
March 19, 2022, 11:39:41 PM »
I found that if it's Hondabond Acetone (Nail Varnish Remover) to be quie effective but you need to try to build up a wet surface so it soaks in & softens the sealant - then use a Muslin type cloth to scrub it away. I found some cloths seem to work better than others.
Quite a redious & time consuming task - seems that the longer the sealant has been there the longer it takes to get off.
I also tried some Silicone Sealer Remover but the results were not as effective as using Acetone.
Link to my full restoration
billdn
SOHC Expert
March 20, 2022, 08:58:44 AM »
Cheers Ted,
From what I can see first time it's been apart, so very old and hard.
Pity the wife doesn't wear nail varnish 😂. Have cellulose thinners so I'll give that a go or down to Boots make up counter.
Sesman
March 20, 2022, 09:49:06 AM »
Agree with Ted. Buy a few litres of acetone from eBay or similar. Wear gloves, glasses and work in the open air
CB350/400
