Author Topic: Liquid gasket on top of everything else?  (Read 7141 times)
Offline alexdecker
« on: March 21, 2022, 06:29:53 PM »
Hey all
How to we feel about liquid casket like this? Shouldn't the gaskets in themselves be enough? Do you guys recommend this?
https://www.cmsnl.com/products/liquid-gasket-1216e_08crahlg120g/
Re: Liquid gasket on top of everything else?
« Reply #1 on: March 21, 2022, 07:03:09 PM »
That’s for the crank case Half’s I think. I wouldn’t recommend it’s use with the correct gaskets.
« Reply #2 on: March 21, 2022, 07:08:59 PM »
Not for these engines, specific use (in product description) refers to water, ethylene glycol resistance used in water cooled engines.
Hondabond is used for crankcase half sealing specifically on this era motorcycle.
« Reply #3 on: March 21, 2022, 07:34:22 PM »
Yup. But what is that stuff used for? I used hondabond by the way….sparingly.
« Reply #4 on: March 21, 2022, 09:04:16 PM »
Mercdes Benz use a liquid only gasket on their sumps for the OM 642 diesel engines also fitted in a range of other vehicles such as Jeep, Chrysler etc.
Personally on an air cooled engine I would stick with Hondabond or similar. (eg Yamibond).
« Last Edit: March 21, 2022, 09:25:23 PM by McCabe-Thiele (Ted) »
« Reply #5 on: March 21, 2022, 09:30:00 PM »
Car sump are a classically cheap non critical (for dimensions) gasket interface along with the old pressed steel rocker covers with minimal bolt fixtures.  No joints on these Honda engines are that type.
It has got amazing material performance, generally very very high heat tolerance too, but properly engineered joints with dowel location and usually needing no flexibility (most joints on these Honda engines) don't require flexibility or that quality in a sealant.
« Reply #6 on: March 21, 2022, 10:50:42 PM »
Sorry to be thick, which is the Hondabondof choice s there are two tube colours, a blue one and a red one, which one for the 550 cases?
Like I say, sorry to be thick :)
« Reply #7 on: March 22, 2022, 06:19:24 AM »
I use Hondabond HT, the Red one. No doubt it’s the wrong one🤔
Offline alexdecker
« Reply #8 on: March 22, 2022, 06:55:11 AM »
Several people says they use blue Hylomar for the crank case halves as well. It is readily available in my region. Can I use that instead?
« Reply #9 on: March 22, 2022, 07:21:34 AM »
Used to use it in the 70's but needs to be VERY thin
« Reply #10 on: March 22, 2022, 08:04:52 AM »
Hylomar blue is the right product for a joint like this but obviously Honda chose their product to match their expectations (don't think Hylomar was available at the time of development) but it does split opinion on here as to which product to use.
Whatever,  and as Bryan says above, you have to use ABSOLUTELY the minimum coating on these surfaces to avoid the risk of having stray/excess floating around inside the engine.
Think about how a self sealing envelope sticky coating is thickness wise.
The surfaces are an "engineered" tolerance design that has to squeeze ALL excess sealant out as you tighten to give accurate location of the crankshaft bearings and how the clearance then works.  Only the smallest amount of sealing remains in the surface imperfections to avoid them leaking,  the remainder is touching metal to metal.
« Reply #11 on: March 22, 2022, 10:58:49 AM »
Sorry to bring agricultural products into this, but both Hondas I've rebuilt in recent years had the crankcase joints done with a thin coat of Harley-Davidson High-Performance Sealant, left over from rebuilding my blown up Sportster.
https://www.harleydavidsondirect.co.uk/products/h-d-high-performance-sealant-gray?currency=GBP
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #12 on: March 22, 2022, 11:02:47 AM »
Um, appreciate the application has to be thin; but how to get that? Smear it with a finger, trowel the bulk off with a plastic blade….. ???
« Reply #13 on: March 22, 2022, 05:02:43 PM »
Oddly enough the thin film is easiest to obtain by squeezing some onto a suitable rubber gloved finger then smear it onto the casing - reload your finger when one it's depleted.
If you put it on the casing first then spread with a gloved finger it ends up thicker for some reason! (Tip from Nurse Julie)
« Reply #14 on: March 22, 2022, 05:30:00 PM »
If your engine doesnt  leak it's probably the right one ;D
I'll order some of that Phil(thunmbs up emoji) ;D ;D
