Author Topic: CB550k1 US Import - UK registration  (Read 177952 times)
Online Oddjob
« Reply #210 on: October 24, 2022, 06:31:45 PM »
2 looks really bad, 1 isn't great either. 3 and 4 looks about average but I'd change them if you're changing the others. Where's 5?
Offline juitz
« Reply #211 on: October 25, 2022, 01:06:22 PM »
Might be a stupid question - but when ordering bearing shells, do you get a fell set (top/bottom) or is it just half?
Online Oddjob
« Reply #212 on: October 25, 2022, 01:29:24 PM »
You need to buy 2 shells for each journal, so 10 main bearing shells and 8 big end or conrod shells and you need to order the correct colour dependent on your crankcase and crankshaft sizes. How to ascertain those sizes is well documented on the forum, just search.
Offline juitz
« Reply #213 on: October 25, 2022, 01:52:42 PM »
That's what I was afraid of. This is gonna be expensive!
« Reply #214 on: October 25, 2022, 02:15:33 PM »
Not much change out of £300.
Offline juitz
« Reply #215 on: October 25, 2022, 04:54:39 PM »
Couple of pics of the crankshaft
Yeah, just costed up new set of crank journals at £170.
Had to go with mainly Greens as Yellow not available anymore. 4 x Green and 1 x Brown
Couple of pics of the crankshaft - nothing notable at least to me to indicate why some of the shells were in poor condition
« Last Edit: October 25, 2022, 05:12:14 PM by juitz »
Online Oddjob
« Reply #216 on: October 25, 2022, 05:44:11 PM »
I've got some yellows if your desperate.
Offline juitz
« Reply #217 on: October 29, 2022, 10:01:45 AM »
Cheers Oddjob,
I want to measure again to double check but for the crank journals I'm at
1 x Brown
1 x green
3 x yellow
Online Oddjob
« Reply #218 on: October 29, 2022, 11:00:50 AM »
So you'd need 6 yellows?
Offline juitz
« Reply #219 on: October 29, 2022, 11:44:21 AM »
Yes that's right - gotta think of these as pairs!
Also, looking closely at the cases and noticed this nick on the top case at the clutch end journal (see photo). How big of an issue is this?
And why doesn't the middle slot on the top case (3rd from rotor end) have a lubrication hole or slot? It seems like the only one on the top and bottom cases?
« Last Edit: October 29, 2022, 11:51:56 AM by juitz »
Online Oddjob
« Reply #220 on: October 29, 2022, 12:01:22 PM »
Shouldn't be an issue, I think the shells don't cover the entire surface anyway. If they do just dress it down a little, won't affect the clearance unless you do the entire surface.
I have 6 yellows if you need them, £15 a shell inc P&P.
I just checked and have 12 yellow mains as it happens.
Still in sealed original bags.
« Reply #221 on: October 29, 2022, 12:14:46 PM »
Weird optical illusion when you click on the photo to enlarge it slightly - if its the edge part you are talking about as long as the bearing sits in the shell I do not see that as an issue.
I noticed the lack of an oil  slot in the centre crank journal - it does seem odd.
Offline juitz
« Reply #222 on: October 29, 2022, 12:20:10 PM »
Ok noticed something very concerning when offering the crank to check clearances with plastigauge using the old shells.
Please correct me if I'm wrong as I'm counting journal positions from the rotor side of the crank.
I noticed theres no clearance between the crankshaft and the 2nd crank journal positions and this has obvious signs of wear, especially on one side.
 All the other positions look to be ok with clearnace on both top and bottom cases?
« Last Edit: October 29, 2022, 12:28:01 PM by juitz »
Offline juitz
« Reply #223 on: October 29, 2022, 12:23:13 PM »
This is what I have just so I'm not crazy 🤣
Took another photo with the shell in but you should see the nick. I don't think it's an issue as the shell is stationary but I'm being careful as I can.
« Last Edit: October 29, 2022, 12:30:24 PM by juitz »
« Reply #224 on: October 29, 2022, 12:23:39 PM »
One journal has less clearance to reduce end float, cars have specific thrust washers but then they also have clutch end load
