Author Topic: STARTER MOTOR GEAR WASHER  (Read 4934 times)
Offline mortyboy
« on: April 17, 2022, 05:16:07 PM »
I'm making my way through my rebuild and notice I'm missing a part for the starter gear:
https://www.cmsnl.com/honda-cb750f1-super-sport-1976-england_model14680/pl-gear-set_28109300000/
It doesn't seem to be available but looks very simple.  Does anyone know of a work-around, ie using/adapting a standard washer?
Cheers   :)
Re: STARTER MOTOR GEAR WASHER
« Reply #1 on: April 17, 2022, 05:53:38 PM »
Its an odd size and hardened from memory
« Reply #2 on: April 17, 2022, 09:39:51 PM »
I was short of this washer but a member had a spare one but spotted this on ebay that includes the washer - expensive for a washer but better than none! The 'shim' is hardened - I can provide sizes if you want but before I got one, I struggled to find anything generically that was similar
https://www.ebay.co.uk/itm/353855811825
« Reply #3 on: April 18, 2022, 04:04:36 AM »
List sizes please Phil as the cb1300 uses a gear exactly like that one and it could be near identical and thus usable
« Reply #4 on: April 18, 2022, 04:26:06 PM »
Here you go - OD 39.88mm - ID 12.25mm - 1mm thick
Offline mortyboy
« Reply #5 on: April 20, 2022, 11:07:43 AM »
[/thankyou Bryan
Offline mortyboy
« Reply #6 on: April 20, 2022, 11:08:42 AM »
Brilliant, thankyou!
Offline mortyboy
« Reply #7 on: April 20, 2022, 11:11:35 AM »
That's great and really helpful.  Thankyou very much. I have a new lathe & mill arriving soon so will try to run one up - along with a few other parts!
« Reply #8 on: April 20, 2022, 11:16:22 AM »
Problem is it's more of a hardened shim than a washer ... there are loads of places who do custom hardened  washer/ shims in the UK.  I had some made for my CB500/4 valves.
« Reply #9 on: April 20, 2022, 12:21:40 PM »
If it's the same as the K1 i have one somewhere.
I could not find mine in the pile of bits that came with the bike, but you guessed it I managed to get hold of one and then found it.
I will have a look tonight.
« Reply #10 on: April 20, 2022, 02:05:28 PM »
Same for all years Paul
« Reply #11 on: April 20, 2022, 02:50:30 PM »
Just got to find it now then  ::)
« Reply #12 on: April 20, 2022, 06:07:57 PM »
Found it  ;D
