Author Topic: 400/4 build. Paused due to other commitments. But starting up again  (Read 142007 times)
Offline ComfySofa
Re: 400/4 build. Paused due to other commitments. But starting up again
« Reply #120 on: November 04, 2022, 09:49:38 PM »
Upper engine mount - is that the triangle connector mounts?
« Reply #121 on: November 04, 2022, 09:54:01 PM »
Yes, negative battery lead connection point.
« Reply #122 on: November 05, 2022, 09:50:03 AM »
I put in a couple of extra hidden extra earthing points - don't ask me where as I have forgotten but it seemed a good idea at the time.
« Last Edit: February 13, 2023, 11:14:19 AM by McCabe-Thiele (Ted) »
Offline ComfySofa
« Reply #123 on: November 05, 2022, 09:52:22 AM »
Just to quote (so run a lead the length of the bike from the battery to the front triangle engine mounts)?
« Reply #124 on: November 05, 2022, 12:12:11 PM »
No it's the rear upper engine mount, it has a small triangular plate, a bent shaped one, the fronts are straight.. The battery earth lead goes on the end of the bolt coming through the engine before the spring washer and nut. I'd remove the paint from the frame where the other 2 bolts holding then plate on connect to the plate and from the small area on the plate that the earth lead covers so it has bare metal underneath.
Offline ComfySofa
« Reply #125 on: November 05, 2022, 12:13:54 PM »
Brilliant - glad i asked now (pics will be coming tomorrow when i get in the garage)! Many thanks.
« Reply #126 on: November 05, 2022, 12:20:20 PM »
My cable was already bent into the shape shown but this is where it goes I believe - I made sure the inside surface against the engine made contact on both sides of the fram if you get my drift.
PXL_20221105_110348178 by Macabe Thiele, on Flickr
« Last Edit: November 05, 2022, 01:08:13 PM by McCabe-Thiele (Ted) »
Offline ComfySofa
« Reply #127 on: November 05, 2022, 12:26:26 PM »
Wow.....ive not even got that bit on there yet!!! ( i was looking at that triangular bit last week) thinking where the #@%$ does that bit go!! Cheers....and i will add that ive got a few more bits like that as well (ill take some pics of them tomorrow)
« Reply #128 on: November 05, 2022, 12:37:20 PM »
Supposed to point upward Ted and the cable should be straight not all curled up like that. I'm currently making some new ones for my bikes, red for the positive lead to the starter solenoid and black for the earth lead and the starter motor cable.
You can always trap the earth point between the engine bracket and the engine, so behind the bracket not in front, that way it makes a really good contact with the engine casing.
Offline ComfySofa
« Reply #129 on: November 05, 2022, 12:40:12 PM »
Great - thanks very much (all good stuff) i will say, that you lot have been a great help....one of the things i was most apprehensive about was the re-assembly after its been apart for so long....
« Reply #130 on: November 05, 2022, 12:43:58 PM »
Welcome, I doubt you have any questions that haven't been asked and answered before. Vast wealth of knowledge on the site.
Offline ComfySofa
« Reply #131 on: November 05, 2022, 01:02:57 PM »
There'll be a shit load of MUnit based electrical ones coming!! :)
« Reply #132 on: November 05, 2022, 01:10:25 PM »
I know Ken but I did not want to risk messing up the cable end by straightening it - when I bought the bike it was attached to the rectifier mounting bolt!
« Last Edit: November 05, 2022, 01:31:11 PM by McCabe-Thiele (Ted) »
Offline ComfySofa
« Reply #133 on: November 05, 2022, 01:39:20 PM »
Ive got everything that came off the bike (well - i think so!) im guessing there is an original earthing strap or is it best to go with fresh wire?
« Reply #134 on: November 05, 2022, 04:31:59 PM »
The original bracket when bought as a spare has no paint either side where the hole is to ensure good contact to engine and cable, as to new or old check for corossion and looseness at the ends if good use it
