Try our re-instated info resource - "Aladdin's Cave" (Main menu)- sorry it's taken so long to fix
Would anyone be able to comment on what they think the value of it would be (for insurance purposes) theyre bound to ask..!
Ooo, do they now, they sound filthy!Where from Bryan??Sent from my iPhone using Tapatalk
Right - well pretty well oem apart from the electrics and the handlebars. That being said ive got everything oem thats come off including all the bolts. I think i might have cut off one bullet connector from the dummy light cluster but thats about it for mods to the OEM...it could be put right back to standard if need be.
I intend to store mine on the ramp, with the ramp raised in the air and with it disabled so it can't be lowered without removing locks etc, don't know how they'd stipulate a ground anchor with that setup.
Quote from: Oddjob on August 04, 2023, 02:54:16 PMI intend to store mine on the ramp, with the ramp raised in the air and with it disabled so it can't be lowered without removing locks etc, don't know how they'd stipulate a ground anchor with that setup.Chain the bike to the ramp, if the ramp is bolted to the floor it is a massive ground anchor.
Quote from: taysidedragon on August 04, 2023, 07:33:16 PMQuote from: Oddjob on August 04, 2023, 02:54:16 PMI intend to store mine on the ramp, with the ramp raised in the air and with it disabled so it can't be lowered without removing locks etc, don't know how they'd stipulate a ground anchor with that setup.Chain the bike to the ramp, if the ramp is bolted to the floor it is a massive ground anchor.I was thinking of putting fold down legs on the corners of the ramp, pumping it up and then dropping the legs and lowering the ramp until it was resting on the legs, that way if the hydraulic seal goes on the ramp it doesn't suddenly drop.
