Author Topic: 400/4 build. Paused due to other commitments. But starting up again  (Read 141831 times)
Offline ComfySofa
Re: 400/4 build. Paused due to other commitments. But starting up again
« Reply #450 on: September 25, 2023, 02:31:21 PM »
Thats ok Bryan...sat at my desk in the office today - ill have a look later on [Roo] when i get home but from recollection its set to enable the main light after the bike has started...its just that it starts the full beam...unless i have to re-configure the m-button barrel shaped thingy in the handlebars...
Offline ComfySofa
« Reply #451 on: September 25, 2023, 05:38:10 PM »
Got me home again! Getting the hang of it now..!
Sent from my SM-G988B using Tapatalk
« Reply #452 on: September 25, 2023, 06:20:38 PM »
Looks very tidy.
Offline gary123
« Reply #453 on: September 25, 2023, 06:26:06 PM »
Looks amazing, great job.
Offline ComfySofa
« Reply #454 on: September 25, 2023, 07:18:33 PM »
Thanks all....thing is now....its nice small bitesize jobs...!
Offline ComfySofa
« Reply #455 on: September 25, 2023, 08:46:29 PM »
Back in the garage...I can see why my Speedo isn't working....think I'm missing something that bolts to the hub and slots in the Speedo drive!?
Offline ComfySofa
« Reply #456 on: September 25, 2023, 08:47:47 PM »
That bit...manual says " gear box retainer"?
« Reply #457 on: September 25, 2023, 09:08:26 PM »
Looks like yours is missing parts 8 & 9 dlis the large o ring missing as well?
Offline ComfySofa
« Reply #458 on: September 25, 2023, 09:10:44 PM »
Probably! its been apart for years so really cant remember! [opening other tab to Dave Silver!]
« Reply #459 on: September 25, 2023, 09:12:39 PM »
I’ve got the o rin Andy, saw it tonight. Might have a spare retainer, I’ll have a shuffle about and see bud. Let me know what you need
Offline ComfySofa
« Reply #460 on: September 25, 2023, 09:16:34 PM »
Oh cool....i think im missing the top left bit (and the o ring of course)!
https://www.ebay.co.uk/itm/295587103899
Offline ComfySofa
« Reply #461 on: September 25, 2023, 10:30:11 PM »
Post fiddling this evening I don't think the charging circuit is working as the munit registered 10.4v at 5pm this afternoon after it had been at work all day...something else to check tomorrow.!
Offline ComfySofa
« Reply #462 on: September 26, 2023, 06:20:21 PM »
Soooooooo, the charging might actually be working.... (im not sure) as theres an munit on it im leaving it on the optimate when its not being used....the checks ive done are....
Run the engine, stick a positive wire from the meter on the battery line.... and im seeing about 12.77v at tickover...if i blip the throttle i see it start to climb to about 12.8....not the usual jump id see from a modern bike...ie 12.5v  - blip the throttle then see it go to over 13v.
Again i grounded the black wire from the meter on the frame and stuck the positive in each of the yellow wires coming from the generator....im seeing about 1.6volts...is that right?
Anymore tests i can do?
Offline Deano400
« Reply #463 on: September 26, 2023, 08:12:03 PM »
I think Bryan did a write up on how to test the charging circuit. Thought it was in Aladins Cave but can't find it. I'm sure Brian will put me right if I'm mistaken.
« Last Edit: September 26, 2023, 08:18:07 PM by Deano400 »
Offline ComfySofa
« Reply #464 on: September 26, 2023, 08:15:04 PM »
Ooh - handy - ill see if i can find it...found a you tube video and ive got the 0.8 resistance between the coils so thats a good start...
