Author Topic: 550 carbs 069A. Question about gaskets.  (Read 5494 times)
Offline Andy1488
  • Nearly at the gym.
« on: April 27, 2022, 11:20:34 AM »
Hi all,, newbie with a question about my carbs.
My intro explains my current project.
Modified cb550(E), with 069A carbs. These have been modded by a PO, which includes the removal of choke butterflies (don't ask).
My main concern is  my leaky bowls,( there's a joke there somewhere).
Anyway, the gasket in question are house shaped,  BUT I think I've also read, or misread that the correct gasket is actually round.
Can somebody please correct me and tell me which ones are the correct ones.. any links etc would be appreciated. [ Guests cannot view attachments ]
Offline SteveW
Re: 550 carbs 069A. Question about gaskets.
« Reply #1 on: April 27, 2022, 11:40:28 AM »
I’m sure mine were round, I held them in place when refitting with a tiny, tiny amount of red rubber grease.
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
« Reply #2 on: April 27, 2022, 11:51:15 AM »
No gasket for the float bowls, it’s an oring seal. Nurse Julie stocks these. The coffin shaped tops are a gasket, but rarely need attention, if required You can make these yourself.
« Reply #3 on: April 27, 2022, 11:53:50 AM »
2nd that, Julie's yer man. (so to speak ;D)
Offline Andy1488
« Reply #4 on: April 27, 2022, 12:27:10 PM »
So it's the round gasket/o ring type...brilliant.
Being new to the site, nurse Julie...???
« Reply #5 on: April 27, 2022, 02:15:37 PM »
She does complete O ring kits for those carbs, send her a pm on here its cheaper than ebay
« Reply #6 on: April 27, 2022, 04:06:25 PM »
With no choke butterflies, how do you start it?
Had to ask
Offline murdock
« Reply #7 on: April 27, 2022, 08:38:50 PM »
somewhere I think I have or have seen the size, they are O-rings, tourmax sells them loose, if you find out the size buy from vitton
Offline Andy1488
« Reply #8 on: April 27, 2022, 09:11:55 PM »
No choke butterflies,,,whoever did the mod, has also altered the carbs richer, upgraded to god knows what coils, but I've never seen a spark like it....little bit of throttle, a quick backfire, then starts on the button with no throttle.  Tickover set slightly higher than normal..its not perfect, but it works. I might revert her to normal carbs, but with the shotgun pipes and the open bell mouths, she runs , she revs, and sounds quite happy.
Offline murdock
Offline Andy1488
« Reply #10 on: April 28, 2022, 10:36:47 AM »
Parts ordered....thank you all...👍..now to post my next question..🤣🤣🤣
