Author Topic: Locks for steering, ignition and seat with one key?  (Read 9490 times)
Offline alexdecker
« on: June 16, 2022, 09:23:59 PM »
Hey all
I can find locks for seat and ignition with the same key. I can't seem to find locks for steering lock, ignition and seat with one key. Does that not exist? My locks and keys are all over the place, and the steering one doesn't work at all. I would like to clean up that mess if possible.
Re: Locks for steering, ignition and seat with one key?
« Reply #1 on: June 16, 2022, 09:31:29 PM »
The steering lock on all my Hondas have been a different type of key to the Igniion/seat/tank lock that are the same.
« Reply #2 on: June 16, 2022, 09:32:21 PM »
WHAT BIKE
« Reply #3 on: June 16, 2022, 09:36:13 PM »
You can get a CB500 with all the same key but not the 550 as they changed the steering lock to one that used a different type of key.
Offline alexdecker
« Reply #4 on: June 16, 2022, 09:36:48 PM »
Offline alexdecker
« Reply #5 on: June 16, 2022, 09:37:20 PM »
Really? I thought they came from the factory with the same key for all three locks?
« Reply #6 on: June 16, 2022, 09:39:37 PM »
Not the 550, as I said, different type of key used when they moved the steering lock from under the bottom yoke to the headstock.
Offline SteveW
« Reply #7 on: June 16, 2022, 10:42:47 PM »
My 74 550 K0 uses the same key for all the locks.
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
« Reply #8 on: June 16, 2022, 10:49:36 PM »
That's because it's a bored out 500 essentially, I'll bet the steering lock is under the bottom yoke.
Does the 550K0 have the ignition lock under the tank still? or between the clocks like the 550F.
Offline SteveW
« Reply #9 on: June 16, 2022, 11:06:25 PM »
Under the tank and steering lock under bottom yoke.
1980 CB650
1981 RD350LC
2011 Henry Hoover
« Reply #10 on: June 17, 2022, 01:50:04 AM »
That’s why it has the same key for all the locks, same as the 500 model.
« Reply #11 on: June 17, 2022, 06:01:31 AM »
Yup, if the steerong lock is on side of headstock its a neiman lock and a different key from seat/ignition
Offline Seabeowner
« Reply #12 on: June 17, 2022, 07:17:07 PM »
My F and K both have the steering lock built into the central ignition switch.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
« Reply #13 on: June 17, 2022, 08:15:08 PM »
That is because you have non UK F1/2 & K3  ;)
Offline alexdecker
« Reply #14 on: June 19, 2022, 10:35:53 AM »
Does that mean that my F2 is a UK model?
