CB350/400
Fuel lines from carbs
Topic: Fuel lines from carbs (Read 3571 times)
Matt_Harrington
July 11, 2022, 06:17:37 PM »
Could someone tell me how long these lines are that are labelled (2)
Do they just 'dangle down' in case of an overflow?
Item (1) was very hard and difficult to remove but I can replicate that one easily.
CB400F 1976 - Almost finished
Nurse Julie
Re: Fuel lines from carbs
July 11, 2022, 06:31:22 PM »
If you make them about the same length, once fitted, as the float bowl drain tubes, that'll be about right. They are air vent tubes, they just dangle down to atmosphere.
Last Edit: July 11, 2022, 06:33:55 PM by Nurse Julie
Matt_Harrington
July 11, 2022, 06:35:48 PM »
Ta very much! I'll let them dangle!
ka-ja
ken
yoshi 460
July 11, 2022, 07:50:27 PM »
They fall between the rear of the engine casing and the frame, and are held together in a square shaped plastic former.
nice bike,nothing in the bank
Deano400
July 11, 2022, 09:41:48 PM »
The two carb vents go over the air manifold and down between the crank case and swing arm.
Matt_Harrington
July 12, 2022, 02:45:01 PM »
Thanks - those are useful for the routing. Matt
CB350/400
