Author Topic: twin disc  (Read 10599 times)
Offline Pauarc
twin disc
« on: July 21, 2022, 09:20:58 PM »
I have now finished my Honda CB750K2 twin disc today
Honda 90ss, Cb250k1 supper sport,
Cb400 four, CB750k7, Cb550, Cb750f2n,
Cb750k2
Offline Arch stanton
Re: twin disc
« Reply #1 on: July 21, 2022, 09:28:08 PM »
Well done.
Have you tried it out yet? Have you experienced any issues?
Like squeaks or drag etc?
Sean.
Offline Pauarc
Re: twin disc
« Reply #2 on: July 22, 2022, 08:11:35 AM »
I road bike for about 15miles all seam ok
bit extra movement on break leaver may change master cylinder
did not notice any drag
paul
Cb750k2
Offline ST1100
Re: twin disc
« Reply #3 on: July 22, 2022, 10:57:37 AM »
... may change master cylinder
I was about to ask which MC you've installed...
What about the speedo-drive? Any issues?
STOC #637
Offline Pauarc
Re: twin disc
« Reply #4 on: July 22, 2022, 02:37:11 PM »
From ebay speedo drive
« Last Edit: July 22, 2022, 02:38:58 PM by Pauarc »
Cb750k2
Offline Pauarc
Re: twin disc
« Reply #5 on: July 22, 2022, 02:52:03 PM »
How it looks fitted
Cb750k2
Re: twin disc
« Reply #6 on: July 22, 2022, 04:25:35 PM »
I had a few squeaks and things. But has improved with pads bedding in.
I use a GL1000 master cylinder. Works perfectly.
Offline Pauarc
Re: twin disc
« Reply #7 on: July 22, 2022, 05:57:34 PM »
That’s good to know I may have a look at the gl1000
Cb750k2
Offline allankelly1
twin disc
« Reply #8 on: July 23, 2022, 09:04:43 PM »
An interesting point of note is for the Yamaha  RDLC the 250 single disc is fitted with a 1/2” Master cylinder and the 350 twin disc a 5/8 M/C but for better feel and less wooden brakes it’s common practice to swap the 5/8 unit to the 1/2 unit
Yes you get slightly more lever movement due to the reduced swept volume of the master cylinder with the smaller bore but the braking is much less wooden
Incidentally for my RD I am running a 14mm M/C but also have two four pot callipers too and floating discs so much better than the original 1 pot sliding caliper per side acting on a solid disc
And on my CB400F twin disc conversion even though I have a extra caliper I have kept the original M/C and not needed to increase my M/C bore size to allow for the extra caliper
Best wishes Al
« Last Edit: July 23, 2022, 09:16:33 PM by allankelly1 »
Offline sprinta
Re: twin disc
« Reply #9 on: July 24, 2022, 09:43:49 AM »
I would agree with the above post. I still have the original master cylinder on my CB750K2 that I did a twin disc conversion on and it is absolutely fine giving more 'feel' to the brake lever and not the solid wooden feel that you very often get with the larger bore master cylinder.
Re: twin disc
« Reply #10 on: July 24, 2022, 03:32:30 PM »
I twin disced a 500 way back in 76 and could not live with the soggy master that came nearly all the way to the grip, at the time Girling were starting to do japanese cylinders , cosmetic seconds i think, so i fitted an early GL1000 one and it was perfect
Re: twin disc
« Reply #11 on: July 25, 2022, 06:06:32 PM »
I've used a GL1000 on the twin disc setup on my CR750 and it feels fine
Re: twin disc
« Reply #12 on: September 04, 2022, 06:47:16 PM »
I’m using a GL1000. It’s mighty fine.
Offline Pauarc
Re: twin disc
« Reply #13 on: September 08, 2022, 09:40:45 AM »
Now I have been using my cb750 and 200miles on I am happy with front brakes much better now
Cb750k2
Offline kevski
Re: twin disc
« Reply #14 on: September 08, 2022, 09:57:27 AM »
When I twinned my K3 500 I used a gl1000 master cylinder, never had any problems.
