Author Topic: CB 500 resurrection  (Read 92616 times)
Offline gary123
Re: CB 500 resurrection
« Reply #225 on: October 11, 2022, 08:11:37 PM »
Yep, done that. Ill try to take some pics.
Offline gary123
« Reply #226 on: October 11, 2022, 08:14:53 PM »
Is it the right rotor for the engine & is it bolted up tight?
The stator is held in place with a series of 3 or 4 bolts into the housing.
Is it the correct housing & stator?
Well I've got a mix of parts but its def 500 or 550. Which I think are the same. They certainly look it and I'm thinking it works cos the engine ran with the battery disconnected.
« Reply #227 on: October 11, 2022, 08:21:42 PM »
So today I couldn't resist a trial start up. After 5 or 6 tries it started and ran and revd.
Can't believe that box of bits with a wheeled frame is already a runner - well done Gary.
Offline gary123
« Reply #228 on: October 11, 2022, 08:23:44 PM »
Cheers Ted, but "runner" is a bit optimistic at the moment.
« Reply #229 on: October 11, 2022, 08:43:43 PM »
Have you got the alternator and stator in the right way round Gary?. There should be clearance if they are fitted correctly. And is the flywheel correctly torqued?
Offline gary123
« Reply #230 on: October 11, 2022, 08:49:11 PM »
Pretty sure I have Julie, but Ill go over it in the morning. Yes torqued up to spec.
« Reply #231 on: October 11, 2022, 09:23:30 PM »
Not a lot of clearance when set right. There is a couple of dowels to align casing. I forgot mine on the 550 start up and I had contact. Was quickly remedied with dowels in place.
Online Bryanj
« Reply #232 on: October 11, 2022, 09:43:53 PM »
Check the rotor is spinning true, i have had a bent crank end before
Offline gary123
« Reply #233 on: October 11, 2022, 10:22:06 PM »
Good point, Ill check.
Offline gary123
« Reply #234 on: October 11, 2022, 10:24:41 PM »
OK, Ill spin it on the starter and see if it "wobbles". Thanks
« Reply #235 on: October 11, 2022, 11:26:10 PM »
Do Not start it without the cover on as, the oil pressure will push the bung out and you will have all the oil on the floor  ;)
Online Bryanj
« Reply #236 on: October 12, 2022, 12:12:33 AM »
Plus the bung will disapear into the dimmest darkest corner of the workshop, not to be seen again until you have taken out a second mortgage to buy the lasy unobtainium one on the planet!
« Reply #237 on: October 12, 2022, 10:13:22 AM »
I did say runner not a rider.lol
I'm still impressed with where you have gotten - my 500 is spread all over my garage in boxes & baskets - I go to sleep trying to imagine what it will look like with a Nut Brown frame - getting to the freezer in our garage is presently akin to an obstacle course.
Offline gary123
« Reply #238 on: October 12, 2022, 10:22:55 AM »
Cheers Trig, thats good advice, and probably what I would have done.
Offline gary123
« Reply #239 on: October 12, 2022, 10:25:10 AM »
Yep, just had to scour the garage for a tank mount rubber that bounced into oblivion.
