Author Topic: Back with a 500 ....  (Read 109152 times)
Offline JezzaPeach
  • CB500/4 K1 1972 gold
Re: Back with a 500 ....
« Reply #60 on: September 05, 2022, 06:56:49 AM »
Good ones, next addition to my tool box!
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
« Reply #61 on: September 05, 2022, 08:29:42 AM »
Obviously not a correct fitting spanner, but a useful addition to tool set are these
Armourers pliers available from some mod overstock supplies or some are made new. Different costs so you need to search around to get reasonable price but I paid £15 for new at a military show for some. They move the jaws completely parallel and substitute for many sizes when pushed to work with limited tools.
« Reply #62 on: September 05, 2022, 10:42:00 AM »
« Reply #63 on: September 05, 2022, 02:06:55 PM »
This is all you need. It's so small, it will fit in the Honda toolbag. Both are 5,5mm. No ratchet needed.
Offline JezzaPeach
« Reply #64 on: September 07, 2022, 08:53:09 PM »
Game on, I just made these out of a couple of old hinges! But I like the parallel pliers.
Perhaps we need a new post on home made tools!! ;D
Offline SPR
  • 1972 500/4 K1
« Reply #65 on: September 08, 2022, 07:47:40 PM »
Small update .... I got a rear light / plate holder and have had it powder coated
I think this was one area that really let the bike down
Pics below of old v new .... I will get the old one stripped and powder coated but suspect it won't come out quite so good
Simon
« Reply #66 on: September 08, 2022, 07:59:06 PM »
That looks well Sy
Offline SPR
  • 1972 500/4 K1
« Reply #67 on: September 08, 2022, 08:30:23 PM »
That looks well Sy
Well to say CMS wanted over £300 for a non genuine one I think I did OK as this cost £60 all in inc powder coating :)
Simon
« Reply #68 on: September 08, 2022, 08:33:25 PM »
Ker Pow!nice one and well worth the dosh.
Offline SPR
  • 1972 500/4 K1
« Reply #69 on: September 10, 2022, 10:00:26 AM »
More progress - the electronic ponits arrived from Mark and took about 10 minutes to fit .....
I also changed all the plug caps and didn't realise just how sloppy a fit the old ones were
Some dremel scothbrite wheels have arrived so may try a little polishing :)
Simon
« Reply #70 on: September 10, 2022, 12:18:00 PM »
This is how I have mine (homebuilt). Never moved a mm.
« Reply #71 on: September 10, 2022, 12:19:30 PM »
I was talking to Mark Paris on his Hondaman system and where to mount it. I asked him if I could open the case so I could attach a bracket but he said that the countersunk screws can be removed and replaced with different ones if you need to do that.
Given all that I either intend to mount mine below the battery case or behind it Simon, just an idea as even though you can't see it, it would look tidier and more secure that way.
« Reply #72 on: September 10, 2022, 12:31:53 PM »
The location of mine has proved excellent. No heat, no vibrations thanks to the six damping rubbers in the battery cage. It's still the same 46 year old rubber strap. Mine is just a little bit canted due to the screws that fasten the power transistors, which helps to secure its position. It's impossible for the box to slide down. BTW, you'd be surprised how much space there is behind that RH side panel. I could have chosen a much bigger box.
Offline SPR
  • 1972 500/4 K1
« Reply #73 on: September 10, 2022, 12:57:36 PM »
It doesn't quite fit behind - that is as far in as I could get it .... I'll take another look and remove the battery to see if I can get it any better
Offline SPR
  • 1972 500/4 K1
« Reply #74 on: September 10, 2022, 12:58:17 PM »
I'll look at that as well .... thanks
