Author Topic: Metal tank badges  (Read 5406 times)
Offline BigAl (Alan)
    • www.alans-electrics.co.uk
Metal tank badges
« on: June 09, 2010, 05:52:13 PM »
Hi all,
 Very simple problem. What is the best way to remove the existing tank badges? I have tried to lever on one side of the badge, but its a bit stiff.
Thanks Alan
Current bikes:-
Honda CB750 K4 (1974) USA
Honda XL500S (1980) UK
Honda CD175 sloper (1968) UK
Honda CB1100A (2013) UK
Offline Seamus
Re: Metal tank badges
« Reply #1 on: June 09, 2010, 07:22:24 PM »
May not help, but the last time I took some off, I levered behind the badges and worked from one end to the other, being careful not to damage the paint. A bit heart in the mouth.
Not sure if heating would help as the badges are retained by plastic grommets (on thew K tanks anyway)
Good luck
Seamus
« Reply #2 on: June 10, 2010, 07:13:25 AM »
The"grommets" are called "J" clips and are actualy steel with the peg on the back of the badge pushing in.
Blunt knife between badge and tank and gently lever
« Reply #3 on: June 10, 2010, 03:41:56 PM »
Thank you for the replies. On inspection the previous owner had used a blob of silicone on each post, took a bit of time to cut around the blob's, but the badges came off eventually !
Thanks again
Alan
Current bikes:-
« Reply #4 on: June 10, 2010, 05:12:09 PM »
Don't you just love PO's
Offline Seamus
« Reply #5 on: June 10, 2010, 09:21:01 PM »
I had forgotten that that sort of thing was done in the past.  :o
Us perfectionists do it propper like  ;)
