Author Topic: Does the 550 share fenders with 750?  (Read 5486 times)
Offline alexdecker
« on: August 10, 2022, 02:11:09 PM »
Am I mistaken, or do these two models share fenders? Both back and front?
Re: Does the 550 share fenders with 750?
« Reply #1 on: August 10, 2022, 05:00:58 PM »
Front yes, back no
Offline alexdecker
« Reply #2 on: August 11, 2022, 06:12:32 AM »
Front yes, back no
Thank you.
Can anyone recommend a good aftermarket rear fender? Doesn’t have to have factory look, can be bopped etc. I would just like it it fit with the existing threads in the CB550F2 frame, so I can just attach it. Does such a thing exists?
Offline mickwinf
« Reply #3 on: August 11, 2022, 08:00:11 AM »
Apparently there are a few differences between the 750/500/550 rear mudguards, different cable holes etc but will interchange as long as you are not a purest. On my 550f2 i have a 750 with a 341 number and it fits fine
Offline alexdecker
« Reply #4 on: August 11, 2022, 08:29:39 AM »
Ah, so the bolt holes line up without any modifications? Could I persuade you to take a picture of the back so I can see the entire fender? Would also like to see how your grab bar and signals lights look like. I assume it’s a grab bar from a 500 you have installed, since you can fit signal lights from a 500 on there? It’s my understanding that there are some significant size differences in the mounting points between models.
« Reply #5 on: August 11, 2022, 08:30:04 AM »
Now you have clarified it yes and yes, US rear ones MAY have only 3 rear light holes for a different bracket and i found some generic ones on ebay, probably for 125 that can be made to fit, even bought one, cost less than£15 if i remember
« Reply #6 on: August 11, 2022, 08:57:27 AM »
I think it was similar to ebay item 275407311712 and at £16 for stainless worth a try
Offline alexdecker
« Reply #7 on: August 11, 2022, 11:50:42 AM »
Damn, that is cheap! Are you happy with it though? At that price, I might spring for one.
How different is the stainless steel look from the chrome in the front?
« Reply #8 on: August 11, 2022, 12:17:46 PM »
My pal bought one for his 550 and its not sized very well. It's meant for a GN 125 which has a smaller back wheel, if you want it to fit you have to spread it out and it looks weird. Save yer money.
Offline alexdecker
« Reply #9 on: August 11, 2022, 12:55:03 PM »
I was thinking it might be a good candidate for bobbing it a little bit. I am aiming for something like this image. Depending on how much smaller the fender is, I don't know, maybe it could work. Totally open for other fender suggestions!
« Reply #10 on: August 11, 2022, 04:51:41 PM »
I've had my fender filled in so the holes are gone and chopping it down somewhat to get a similar look once chromed.
Offline mickwinf
« Reply #11 on: August 11, 2022, 05:32:23 PM »
The picture of my 550 has the correct 550f2 grab rail, and yes it does fit the older smaller indicators only on uk models, hence the stems are hard to find. Usa and other markets use the later larger indicators like on the 550 k3.
« Reply #12 on: August 11, 2022, 07:48:27 PM »
Havent actually fitted it yet, has sharp edges and yes does look different but i rekon its ok as long as you are not after concourse. I think the us rear light mount should fit the 3 holes
