Author Topic: 400F Throttle plate on carbs.....  (Read 960 times)
Offline Matt_Harrington
« on: September 05, 2022, 06:19:30 PM »
There is a shaft on the plate that holds the carb bodies together. This shaft has the throttle quadrants on it.
I would like to remove this shaft from the plate to re-plate the quadrants. Is it held in place with a brass pin?  - ie does this require drilling out?
Re: 400F Throttle plate on carbs.....
« Reply #1 on: September 05, 2022, 06:22:11 PM »
Yes it needs drilling out Matt.
« Reply #2 on: September 05, 2022, 06:24:41 PM »
Once I drilled mine out I replaced it with a roll pin, worked a treat.
1976 Honda 400/4
« Reply #3 on: September 05, 2022, 06:26:23 PM »
Thanks guys.  Answers my question - and in a thrice!
