Author Topic: Teds new project a CB500 K1 mostly version 0.5 circa 1972.  (Read 298977 times)
Re: Teds new project a CB500 K0 circa 1972.
« Reply #375 on: December 19, 2022, 08:10:24 PM »
Purists look away now - my DS Chrome finished plastic headlamp bowl & aftermaket rim kit arrived today so I was able to fit a neat Land Rover LED headlamp unit without any alterations.
Thanks for the tip Allankelly & the link. https://www.ebay.co.uk/itm/303960372602
 .500 LED headlamp by Macabe Thiele, on Flickr
« Reply #376 on: December 19, 2022, 08:12:56 PM »
Like that Ted. Novel and functional👏
« Reply #377 on: December 19, 2022, 08:29:38 PM »
Give over Ted, that's ace and solves an issue rather well. I have the standard shell and lens for mine but looking at others too for ideas as it looks like half a beach ball, its massive!
I'd say yours is spot on mate and an easy win too, ;) :)
Offline SPR
  • 1972 500/4 K1
« Reply #378 on: December 19, 2022, 08:36:34 PM »
Go for it Ted  ;D
« Reply #379 on: December 19, 2022, 08:42:01 PM »
Oh plus the sidelight is a slightly dated but was trendy Halo / Angel eyes type.
« Reply #380 on: December 19, 2022, 08:47:55 PM »
\halo, how posh!
Get you! ;) :D
« Reply #381 on: December 19, 2022, 10:20:00 PM »
\halo, how posh!
Get you! ;) :D
Not so much posh as Christmas themed -  Halo / Angel. ;D ;D ;D
« Reply #382 on: December 19, 2022, 11:42:52 PM »
 ;D
« Reply #383 on: December 20, 2022, 12:22:56 PM »
Does that have DOT (DOT approved) stamp on the lamp, if not you might struggle to get it through the MOT if it needs one.
« Reply #384 on: December 20, 2022, 02:41:14 PM »
Yes it has the DOT SAE E9 stamp on the outer edge it has Osram LED's similar cheaper ones do not.
« Reply #385 on: December 20, 2022, 03:06:11 PM »
Spent a lot of time bimbling about sorting out what bits were where - putting some parts in Evaporust etc.
It's much warmer today so I've been doing some work on both lower fork legs cleaning out the threads & the sediment inside the legs.
I need to do some more polishing on the right fork leg as ther left one is much shinier at the moment.
Once I am happy with the polishing of the fork legs I can get the front suspension fitted with a view to fitting the front wheel for better frame stability.
When the cold weather returns I can do some soldering on the Pilot light loom now I have some better lamp holders & rubber shroud fitting thingys.
« Reply #386 on: December 20, 2022, 03:07:43 PM »
AFAIK Paul so long as it passes the beam pattern test it should pass the MOT. Same for when you fit an LED bulb into a regular headlight. Mine passed no problem this year.
« Reply #387 on: December 20, 2022, 03:09:15 PM »
Your not thinking of doing the double disc conversion Ted? Makes the front end look more balanced IMO and of course braking is improved.
« Reply #388 on: December 20, 2022, 03:32:00 PM »
Sounds like an expensive alteration Ken.
« Reply #389 on: December 20, 2022, 03:37:46 PM »
Depends on what you already have Ted, you need a spare caliper and disc, a set of 550 sliders, a longer set of disc bolts and another part of the brake line. Not that expensive if you already have some of these. There's a little work involved as well adapting the speedo drive.
For me it's a good investment, if it stops you quicker it could just avoid an accident and those can be very expensive.
