Author Topic: CB 750/550 Front Caliper  (Read 30764 times)
Offline scottly
Re: CB 750/550 Front Caliper
« Reply #15 on: April 17, 2026, 06:31:50 PM »
So what your saying is if I understand you correctly that 750 calliper won't fit onto a 550 ?
Actually, you can use a 750 caliper on a 550 if a 750 rotor is used, provided the 750 caliper uses the later mounts. This will give additional braking due to the larger 296mm vs 276mm diameter.
Seeley SH7-521 owned since 1979
